New toshiba 32rv530u lcd tv has no video but the audio works when tv is turned on screen comes on for a second, goes black, comes on again, then goes black again permantly
I have exactly the same problem which started last week. The TV was made in February 2008. I have contacted Toshiba and they are sending out a local service rep. I have exactly the same problem which started last week. The TV was made in February 2008. I have contacted Toshiba and they are sending out a local service rep.
AnonymousMar 12, 2014
tv turns on and works but after some time; the screen flashes with bright light and goes black.tv turns on and works but after some time; the screen flashes with bright light and goes black.
AnonymousMar 18, 2014
i turn it on screen shows for a second then goes blacki turn it on screen shows for a second then goes black
AnonymousMar 25, 2014
My tv will stay on but the picture goes black and my tv wont show a picture unless you turn it off and back on againMy tv will stay on but the picture goes black and my tv wont show a picture unless you turn it off and back on again
You can't post conmments that contain an email address.
I have seen many tvs at work, if the backlight isn't burnt on the far tips, after opening the tv and all, check your caps, if nthere is blown caps also check for fuses resistores diodes, fuses on a circuit board (small ones) are labeled f# I have seen many tvs at work, if the backlight isn't burnt on the far tips, after opening the tv and all, check your caps, if nthere is blown caps also check for fuses resistores diodes, fuses on a circuit board (small ones) are labeled f#
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/
Replace the damaged capacitor and check first. If it do not help you, replace the power supply regulator board as card. It will be best, rather than trying to make the present one get repaired.
I have the same problem with a 40" Toshiba LCD, Component cables work fine with FIOS but not HMDI, goes in and out then blank. HDMI with DVD player works fine. Best buy reported this same problem from users with this toshiba lcd but no solution.
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
was not the backlight thanks
