Televison & Video Logo
Anonymous Posted on Feb 01, 2009
Res.Burn I have a Mitsubishi VS-5041 projection tv (I have Res.burn Loc.R2200
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 346 Answers
  • Posted on Feb 02, 2009
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
346
Questions
Helped
91264
Points
559
Call the manufacturer
give them the name of tv and the model number of the tv
give them the location number r2200
you can order it
Mitsubishi VS-5041
your set is not a DLP its a traditional rear projection tv set and has three picture tubes
there is not a bulb or color wheel in this model
if its dead ? you would need to check the power supply first to see if you have the proper voltages . the trouble shoot the rest of the circuits to see what is shutting it down . convergence circuit failure is always a good suspect in these sets
1helpful
What's the matter with my Mitsubishi Big Screen Tv Model VS-5041?
just re-read the trouble-shooting section of your owners manual and check the setup on your remote
1helpful
Blurry mitsubishi projection VS 5041
there a one or more defective tube needs to be replaced is typical efect when is tube end of life.
Any idea on where i might find a user manual for mitsubishi vs-5041 -to program the remote??? :) thankyou [email protected] kim stansel
just go to mits site and download the manual. i have a mits too and your manual is there. just use all info u have to search.
Mitsubishi vs-5041 -after a few hours on, the tv goes black
Get the projection bulb checked if fine its something internal in your tv but i think you need new bulb
Mitsubishi big screen won't stay on!
Its very possible you have a failing resistor r2200
Remote for tv in closed cabinet
i don't know about the dip switch, but the ir receiver board in this mitsu is located in front of the mirror behind the screens
2answers
Mitsubishi VS-5041
if you know someone with a dish network remote they have a cancel button.... i had the same problem and fixed it this way
1helpful
2answers
Mitsubishi VS-5041 (TV turns on but no pic or sound)
Your problem is one and or 2 differant problems. The power regulator could have went bad because of the convergence IC have shorted. Seen this a thousand(easy that!)Times. All parts in this set are soldered in and are not user serviceable. look in your owners manual or call 800-332-2119 to get an authorized servicer to come and look at your problem . I wish i could tell you what to replace but theres the Extreme Hi voltage inside these sets even when they are not plugged in .. Good Luck
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
