To remove the region code on your Samsung Blu-ray player, you can follow the steps below:
Step 1
Power on Samsung Blu-Ray E350K, the make sure to remove disc in the tray.
Step 2
Now, close tray. the screen should says "no disk"
Step 3
Press the BLACK button BELOW the yellow "C" button.
caution: by mistake if you press the repeat A-B button bellow the green "B" button, these instruction will not work
Step 4
Press 7-6-8-8-4 (or your region code).
Step 5
The current region code will display at the top left of the screen.
Step 6
Press 9 to change to free region.
Step 7
Power off using the Samsung remote, then Power On using the Samsung remote
Step 8
Repeat steps 1 to 4, your region code will now show a "0" on the top left corner.
Alternatively, you can use Leawo Blu-ray Copy to remove region code on your discs, so that you can play them to any Blu-ray players.
You may find an exclusive way to hack your DVD player and make it region free, chances are there is not your DVD player model on the website, or your DVD player is not hackable at all.
You can use a region free DVD player program to play your region-locked DVD discs on your computer. You can try Leawo Blu-ray Player. Leawo Blu-ray Player is the very program you can use to bypass the DVD region code of a disc.
SOURCE: How can I make Samsung Home Theater HT-TWZ312 DVD Region Free
there is no region hack for.......
but please try the following code may be works>>
1. Remove disc from tray.
2. Switch off player and unplug from mains.
3. Wait 30 seconds, then reconnect mains.
4. Turn on player with remote. Wait for player to finish loading and display 'no disc'.
5. Press enter on remote. (There will be no on-screen response.)
6. Press 8, 4, 2, 6, 9 on the remote. (There will be no on-screen response.)
7. Press enter on the remote. Player will automatically shut off.
8. Turn player on.
9. Turn off.
10. Turn player on then off again.
11. Player is now region-free.
Thanks for using FixYa.
SOURCE: samsung ht-x20 unlock codes
http://www.videohelp.com/dvdhacks/samsung-ht-x20/8981
This should solve it :) I had similar problem.
Swapnil
SOURCE: Sammi Jones must be an Indian spammer on FIXYA --- samsung HT x20 region code
For Samsung HT-X20 the region code unlock listed workd perfectly. Just hit 8,4,2,6,9 then ENTER (do this twice) and it will play your DVD which it did not before.
Abe
SOURCE: Region Free Code for HT-Z310T Samsung Home Theatre
8. Turn player on.
9. turn off.
10. Turn player off then on again.
My brother did this on his ht-z310 and other than I think maybe the traty not openin g when it said it worked fine and his player is now region free.
I got this btw from:
http://www.videohelp.com/dvdhacks?dv...&Search=Search
SOURCE: unknown disc for all region 2 discs for samsung ht-x30
First your DVD player has to reset, by pressing stop and play botton simantaneously, and then try 84269
