Question about Fisher and Paykel Washing Machines
Fisher and paykel MW511 series 11, phase 6, control panel lights up, beeps through all buttons, but start button beeps but doesn't start
    Master:
  • Fisher and P... Master
  • 745 Answers
There is a lid switch located under the top of the machine on the right hand side activated by a magnet in the lid this is probable faulty
Posted on Apr 21, 2018
6ya staff
SOURCE:
JULIANFIX
ALBERT GARCIA
  • 975 Answers
SOURCE: fisher & paykel (mw511)
check out the DRAIN MOTOR PUMP , its a small motor with 2 hoses connected to it , it could be clogged , need to remove it , inspect inside the impellers for any debri , clean it , re install and try again , hope this helpful AJ
Posted on May 20, 2008
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Start up Fault
there should be a trouble shooter in the console the blinking lights will tell you what the problem is and the common issues are listed on that paper.
Posted on Nov 09, 2008
Anonymous
  • 14 Answers
SOURCE: fisher and paykel mw511
temp sensor is bad or dirty with hard water deposits
Posted on Feb 22, 2009
Anonymous
  • 187 Answers
SOURCE: lights on but wont start- can I reset it model GW608 fisher &paykel
  • Hi,
  • try these:
  1. Check that the washer is plugged in securely
  2. Check the circuit breaker or fuse box
  3. Test the outlet for current
  4. Check that the water supply valves are turned on
  5. Inspect the filter screens
  6. Test for overheating
  7. Test the water level switch
  8. Test the timer control
  9. Test the lid switch
  10. Test the water inlet valve
  11. Inspect the water pump
  12. Test the centrifugal switch
  13. Test the motor
please rate my suggestion....
Posted on May 22, 2009
MNfisherman
Nate Stansfield
  • 11896 Answers
SOURCE: fisher paykel GW 11, no power to panel.
You will have to check the power from power supply to relay to control panel. You can check for voltage with multi-tester or voltmeter
Posted on Jul 07, 2009
My Fisher & Paykel 708 smart drive washing machine won't starts and beeps.
That is Error code 9
9.
(00001001) Phase 1 to 5 - Size Error
Phase 4 to 5
The Display size switch setting does not match that stored in memory.
Action - Reselect the size of Smartdrive by using the SIZE SETTING MODE. Push and hold
the water temp up button, then press the power button to enter SIZE SETTING MODE. Three
LEDs are used to identify size. The cold water temperature LED identifies 5kg. The low water
level LED identifies 6kg. The hold spin speed LED identifies 7kg. If the product has not been
setup before all 3 LEDs will be on. To set the size for 5kg push the wash temp up button then
the power button. To set the size for 6kg push the water level up button then the power button.
To set the size for 7kg push the spin speed up button then the power button. This locks the size
into memory. To check the size is set, start a cycle.
Dec 20, 2012 | Fisher and Paykel Washing Machines
F & P MW511 Washing Machine ... Driving me Mad ... Please Help!
Size setting
The low water level LED identifies 6kg.
If the product has not been setup before all 3 LEDs will be on.
the power button.
This locks the size
Aug 16, 2012 | Fisher and Paykel Fisher & Paykel Washer
I am having problems with MW511 - it has just started going into rinse cycle then stopping and lights number 2 and 8 come on with a constant beeping, when I press pause the lid locked light comes on as...
(01000001) Phase 5 and 6 - Pressure Transducer (Ptx) error frequency > 90kHzThe Motor Controller module has received signals from the water level sensor (Ptx)above normal frequency values.Primary Source: Motor Controller module.Action:Replace Motor Controller module.
May 11, 2012 | Fisher and Paykel Washing Machines
MW511. 2 & 7 lights flash, beeping. No agitate or spin?
Fault code 66 is pressure sensor is faulty
66. (01000001) Pressure Transducer Error [Ptx Frequency > 90 kHz]
Note: this supersedes Fault code 65 from V41 Motor controller code onwards.
The Motor Control module has received signals from the water level sensor (Ptx)
Primary Source: Motor Control module
Action: Replace Motor Control module
Apr 20, 2012 | Fisher and Paykel Washing Machines
Washing mashine MW511 top loader was running good but this morning tried to start but it is making a beep beep tone and flashing lights
It is giving out a fault code,
Of the 8 wash progress lights, tell me witch are on,
I will tell you the fault code and info on how to fix.
Jan 29, 2012 | Fisher and Paykel Washing Machines
Hello, my MW511 Fiisher and Paykel top loader washer is not working, the lid locked light keeps flashing before the spin cycle and it keeps beeping and never starts the spin cycle... what can be wrong? I...
Hi - you may have somehow put the machine into data mode - its either that or the door lock itself has malfunctioned - the only other logical one is thw controller module.
I'm assuming its a Phase 6 - try this - press/hold wash temp & power button until u get 2 beeps & lights up - release buttons...
NOW IMPORTANT - be careful you are in memory system of the controller -
1. press start/pause to unlock/lock & toggle that lid locked lights - check default is off.
2. I think its either advance or regular to turn pump on/off.
3. try a few buttons see what happens - THEN
turn off at the wall & try it again, if it still doesn't work then we may have a more sinister problem which will require correct testing of the components.
This will require a thorough knowledge of how to interpret the test results, to nail the culprit.
Sorry cannot help further...
Jun 30, 2011 | Fisher and Paykel Washing Machines
Fisher & Paykel GW612 beeps before spin.
You have fault code 66 (01000010) Phase 6- Pressure Transducer (Ptx) Error - Frequency >90kHZ. In simple terms you need to replace the main "Motor Control Module" Cheers
Mar 09, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & paykel mw511 pride
Check the pipes actually work first. Is there a hidden drain filter that is partially blocked? Dissasemble the pump and check it works and the blades inside are clean.
Jun 13, 2017 | Fisher and Paykel Fisher Paykel Intuitive...
Start up Fault
Nov 08, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
67 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
peter gittos
peter gittos
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
