Just wanted to post and say THANK YOU GRIMLAC. That worked perfectly. I already had the driver and bitpim installed but assumed that it wouldn't work because all the options were greyed out and I couldn't get it to see the u340 as another specific model (rather than "Other"). Accessing the filesystem however, allowed me to get 29 pictures off of my phone that I've never seen outside the 2" screen. Thank you so much!
SOURCE: download pics from my samsung sch-u340 phone to my computer
i have the same phone. got the data cable for $2 at amazon. The free USB driver can be found here:
http://www.samsung.com/us/support/download/supportDown.do?model_nm=SCH-U340&mType=SW&vType=L&disp_nm=SCH-u340
make sure you install this driver and reboot BEFORE you connect the phone to your computer
Next download BitPim at www.bitpim.org. it should find your phone right away.select view filesystem from the view menu. You will then select the directory mm then open pg then default album will have the photos. right click on the .jpg file you want to save to your hard disk or if you right click on the directory (default album) you can select backup which will create a zip file of all the pictures and copy it to your computer. This soulution works on windows XP. Hope this helps
SOURCE: Ringtone Downloads Samsung SCH-U340
I have the same phone. go to www.myxertones.com and thre you can find ringtones for free or that phone.
SOURCE: Brand new Samsung Sch-U340.Noone can hear me and i cant hear them
Try dialing *22899 and press send.
If that doesn't auto update the phone (you will see on the screen if it does) try *22899# and press send.
Try call again.
SOURCE: Trying to unlock a samsung u340
Do you have the codes already or are you looking for the codes ?
If your looking for the codes come visist us.
If you have the codes already the company you got the codes from should have support.
