It's been sitting for months without being used, and now I've tried and nothing happens. I've check all electric circuit and wiring on machine, all appears fine. This machine is like new, hardly ever used , HELP
SOURCE: While running the machine would
OPEN THE THE GRIPPER WHICH YOU SAID IS CRACKED BY REMOVING THE SCREWS HOLDING IT AND TRY RUNNING THE MACHINE.ALSO CHECK THE SMALL WHEEL LOCATED IN THE CENTER OF THE WHEEL, THIS HAS TO BE TIGHTENED BY TURNING IN THE REVERSE DIRECTION.
REGARDS.
SOURCE: I'm using the Alphabet Card
Hi, well if it works OK on "Other" cards? Then most likely the problem is with the "Card" it maybe corrupted etc? The ONLY real way to tell is to obtain an exact same card and try that, now, if, as I suspect, it works fine, then the answer is obvious, you need a new card to replace the damaged one. If however it is still not working, then there maybe some incompatibility between that card, or type of card, and the machine? in this event you would have to contact the manufacturer and report this and see what they say? You may need an update or the like? Only they could guide you on this in this case.
SOURCE: i have a brand new reliable industrial sewing
hi.
given that the machine is only a month or so old, the best advice i can give you is to do nothing to the machine and call the sewing machine guy out to repair it for you. a brand new machine like this will be covered by the warranty. as long as you have actually switched the machine on properly, any faults are the responsibility of the supplier at this stage.
SOURCE: Silvercrest overlocker - the 'red' pathway thread won't progress through
have you tried changing the needle?
since you've only had the machine for a week, I'd suggest taking it back & getting another machine.
SOURCE: my brother embroidery machine's lcd screen is blank
Hi.
On page 81 of your manual it says to adjust your LCD screen brightness.
If you can't find your manual... go here and download it.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_PE_770%20%20%E2%80%93%20New!_EN_1819.PDF
