SOURCE: I have a front-loading LG washer model WD 80150TP.
Hi.
If it is an high pitched noise or a rumble that gets muc louder when the machine spins at speed, then it is usually the drum bearing. the drum bearing is located at the back of the drum. Replacement requires disassembling of parts of the machine. You remove back panel and you will probably need the top out. You undo the belt taking note of the routing and replace the bearing. The repair must be done by someone with experience.
If instead the noise is a rattling coin-like noise, then you have objects trapped in the drain filter. The drain filter can be accessed using the service door in front, at the base of the washer on one side. Open the access, rotate anticlockwise the cap and collect water from drain filter. After that remove blockage and foreign objects.
Regards.
Ginko
