Question about Samsung Office Equipment & Supplies
Internal error - IllegalResolution in excel printing
  • Samsung Master
  • 3,267 Answers
Using a high dots-per-inch (dpi) resolution for printing produces quality printing results, but it may take longer to print. You can change the resolution settings to a lower dpi setting, depending on the type of printer that you use. If the printer that you use supports draft quality printing, you can specify draft quality for faster printing instead.
Posted on Dec 04, 2015
2 Suggested Answers
6ya staff
SOURCE:
Trojaner
  • 111 Answers
SOURCE: i want to print an
you can try to print it as an image, but it will take longer to print it, sometimes the mallfunktion okures when the printer driver is not correkt installed, then you need to remove the driver from your computer and reboot it before you install it new, hope this solfe the problem.
Posted on May 18, 2011
Prompt the good instrument of repair of Excel Files?
You can try XLSX Repair Kit ( - MS Excel XLSX repair tool ) - XLSX file repair software for corrupt Excel workbook. XLSX Repair Kit helps to repair XLSX file content ASAP.
Jan 31, 2016 | Acer Aspire One PC Notebook
In Excel I have page breaks and wish to hide some pages but when printing the hidden pages print as blank pages and print preview jumps from page before and page after but includes the hidden page num
Don't put anything in blank pages, not even a space, now select the pages those you want to print and print selection.
It must help you out
It will locate all error containing cells, now rectify the error save it reopen in excel to see if problem is solved.
Aug 02, 2014 | Microsoft Excel for PC
I want to print an excel sheet but he prints: SPL-C eroor - IllegalResolution Position : 0x0 (0) system : src/xl_tbl Line : 771 VERSION : SPL-C 5.35 11-20-2007
May 17, 2011 | Samsung CLP 315 Laser Printer
Printing problems
GO ON LINE AND TYPE IN THE FOLLOWING INFORMATION.
EXCEL ERROR PCL XL ERROR
ENTER
LASERJET ERROR KERNEL ILLEGAL OPERATORS SEQUENCE ENDCHAR POSITION 293
ENTER
CALL THE MANUFACTURES CUSTOMER SERVICE LINE AND ASK FOR TECHN SUPPORT AND GET THE RIGHT ANSWER TO THIS COMPLEX QUESTION PLEASE
ROD GANDY
Jan 22, 2009 | HP LaserJet 4250n Printer
Problems with printer settings
Interesting. I tried printing a simple 3-page Excel spreadsheet sent my by a colleague to my 8500DN from Microsoft's Excel Viewer and got a timeout error formatted as follows:
ERROR: timeout
OFFENDING COMMAND: timeout
STACK:
42
-mark-
(84,160)
No idea what this means, but resetting the network parameters (even though I use USB connection) from the printer's front panel cleared the problem. The printer would print nothing else from any program until I performed this reset. Wonder if Excel futzes with settings and printing somehow?
Oct 14, 2008 | Xerox Phaser 8500/DN Printer
Printer cant print excel files
Chjange the page size of the excel document, it at present is set to letter, ...file page set up in excel
Sep 23, 2008 | HP LaserJet 4 plus Printer
My hp laserjet 4 plus printer cannot print excel files
wherer are you printing this, A4 is european, north america would use letter, etc..
if you go to control panel, open the printers and faxes folder, right click the printer in question, a window will pop up, click on properties.. a new window should open. click on "Printing Defaults" or "Printing Preferences" then click on "Advanced" ( I believe it should be to the lower left) that will open another window, in paper size make it Letter if your in N America, A4 for Euro.. this will set the deafult print..
Click ok, then print a test page from the general tab..
The reason you getting this LOAD LETTER message. your excel page setup is set to print to letter, your machine is set to print top A4
If you open Excel then go to Print then a window should pop up where you select the printer you want to use, click on Properties, then Lay out, then Advanced, and input the correct paper size before you print.
does this happen with all excels files, or one particular?
Create a new Excel file, and try printing it.. possibly could be in that particular file. I have seen this happen alott particulary with PDF files.. Where the incorrect paper size is in the file..
MS EXCEL 2000 corrupted workbooks/worksheets
it sounds like you are going over the limits of the program these are the specs. I would recommend dividing up the data if you can. or moving it to a database that can act like excel and hold more data.
Apr 29, 2008 | Microsoft Excel for PC
Laser printer error
first you most insure where is the problem by diagnostic it
reinstall the printer driver
be sure that the excel application work properly by tray to print in another printer
Mar 16, 2008 | Brother HL 1440 Laser Printer
Crooked Excel Spreadsheet
I also had this problem, through trial and error I found that if you go into File, Page setup in excel then the Page tab, make sure the print quality is set to 600 dpi. Once I did that it printed correctly.
Jan 22, 2008 | HP OfficeJet 6110 All-In-One InkJet...
789 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
