SOURCE: how can i change my panasonic nv-gs230 mini dv
Best
1. Copy the video to your computer with WinDV. No "capturing" involved. The video resolution and PAL/NTSC format will be the same as the source.
2. Then convert to whatever format you like.
You could also use something that copy and converts the video directly from the DV, like convert to dvd with Ulead DVD Workshop.
DV is a fixed standard and comes in 50Hz and 60Hz versions.
50Hz ("PAL" 625/50) 720x576, 25fps interlace (aka 576i)
4:2:0 components, 25Mb/s Video Rate
LPCM audio 2ch 16bit 48KHz or 4ch 12bit 32kHz
60Hz ("NTSC" 525/60) 720x480, 29.97fps interlace (aka 480i)
4:1:1 components, 25Mb/s Video Rate
Meaning, You cannot change the camera. It is either a pal camera or a ntsc camera. Othewise you will have to by a firmware update from the manufacture's website.
