Question about Sony BRAVIA Televison & Video
Bravia KDL 32w4000 picture aspect problem, I am having problems with the size of the picture on this tv. I am viewing it via virgin media and whatever screen format I choose, 4:3, wide, smart, zoom et
Bravia 32w4000 picture aspect problem, I am having problems with the size of the picture on this tv. I am viewing it via virgin media and whatever screen format I choose, 4:3, wide, smart, zoom etc I can't see the horizontal edges of the picture. Is ther anyway to alter the picture or settings? does anyone else have this problem? Can anyone help?
  • nick Feb 02, 2013
    I forgot to mention that when watching a DVD the picture aspect is perfect.
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
Posted on May 30, 2008
Anonymous
  • 320 Answers
SOURCE: Normal Picture Mode Not Available With Cox HD-DVR (Motorola DCH3416) and HDMI Cable
With an HDMI cable connected, the cable box determines the picture size. The settings on the cable box must be changed in order for you to get the correct picture size. I have some experience with Motorola cable boxes; usually to access the settings you turn the box OFF and then press the menu or settings button on the box to bring up the display menu. Hope this helps!
Posted on Oct 19, 2008
Anonymous
  • 541 Answers
SOURCE: My Sony Bravia has many options regarding the
If you can get Sony's customer service they should be able to help.
Posted on Oct 13, 2009
Steve Yocum
  • 668 Answers
SOURCE: picture size exceeds TV screen
If you are also using a Cable Box, make sure that the zoom selection, (Format) ,on the Cable Box remote is set properly. Especially if the TV Remotes Aspect Ratio is set to a Wide Format.
Hope this helps,
Skyassoc
Posted on Oct 21, 2009
Stuck on zoom adjustmen greyed out how do i fix
Look for button on the Sony remote labeled ASPECT , PICTURE SIZE, WIDE OR FORMAT. Press it until desired picture size.
Aug 30, 2011 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony kdl 32w4000. Works ok for 10-15mins, then there's a buzz through the speakers and it switches off with the standby light flashing 8 times
Please try this TV on an alternative power source. It sounds like it is getting either too much or inconsistent power from the plug it is plugged into. I recommend trying a completely different wall, as often times one wall with multiple plugs will be on the same circuit.
Good Luck.
Jesse Lohse
Jan 06, 2010 | Sony BRAVIA KDL-40V3000 Television
The picture is too big for the screen and i can't get it reduced
Change aspect ratio of screen through screen format option in Menu.
Hope this will fix your screen size issue in Sony KDL-52W3000 tv.
Thanks.
Dec 27, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Vertical needs adjusted. both bottom and top of screen are cut off
On the remote look for a button labeled aspect,zoom or picture size. Press that button repeatedly until the picture is the desired size.
Nov 21, 2009 | Sony BRAVIA KDL-40XBR2 40 in. LCD HDTV
How do you get full screen on tv
Aspect ratio button - - A square with arrows pointing out of all sides.. will change any picture across teh TV's different sizes - wide, smart 16:9 ect.
To clarify though, what type of picture is being sent into the TV?
You have a sky box ..?! Or just photos or something?
Nov 15, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony KDL-40WL140 vs KDL-40Z4100
KDL40Z4100 Product Features
  • 16:9 Full HD 1080p Resolution (1920x1080p) LCD Panel
  • Motionflow 120Hz; improves TV & DVD viewing
  • DMeX compatible; allows seamless feature upgrades
  • DLNA® Compliant - view photos from another room
  • HDMI x4, HD Component x2, PC Input
Technical Details
  • Brand Name: Sony
  • Model: KDL-40Z4100/B
  • Display Technology: TFT active matrix
  • Display Size: 40 inches
  • Image Aspect Ratio: 16:9
  • is_hdtv_compatible: Y
  • speakers_included_description: 2 speakers
  • Height: 23.9 inches
  • Width: 37.2 inches
  • Depth: 2.8 inches
  • Weight: 39.7 pounds
  • Refresh Rate: 120
KDL-40WL140 Product Features
  • Motionflow™ 120Hz - clear, smooth motion for DVDs, TV
  • DMex ™ compatible; allows seamless feature upgrades
  • Enhanced XMB™ with 3D graphics incl. TV Guide
  • HDMI™ x4, HD Component x2, PC Input
Technical Details
  • Brand Name: Sony
  • Model: KDL-40W4100
  • Height: 25.4 inches
  • Width: 38.8 inches
  • Depth: 4.3 inches
  • Weight: 44.1 pounds
  • Refresh Rate: 120
Bottom line for the extra connectivity and DLNA certification i would go with the
Bravia Z-Series KDL-40Z4100/B 40-Inch 1080pBecause if you connect this to your in home network you can stream music videos and music off you PC onto your TV without the need for extra wired or memory cards etc.
Otherwise if you don't need this feature the other options are identical on the other TV so it is just as good a choice.
May 25, 2009 | Sony Bravia Z KDL40Z4100 TV
Bravia & Sky+HD, aspect problem
There is nothing wrong with you Sony Bravia TV and it suppport all HD and SD formats.
Are you viewing the HD version of the channel when it is showing a standard defination show. e.g SKY1 HD instead of SKY1.
This means that regular standard defination shows are in a 4:3 ratio and does not fill the whole screen. In order to view these type of shows you will need to tune to regular channel instead of the HD version.
You can check if a show is brocast in HD by going into the tv guide and checking for the HD symbol in the programme symposis.
Example
Apr 13, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony Bravia - picture don't fit the screen
I have a Scientific Atlanta cable box w/ Time Warner. I followed the instructions below for the cable box. Somehow it reset my picture and I can now read the ticker at the bottom of the screen and the different picture sizes seem to work properly. Good Luck.
http://newteevee.com/2007/12/15/six-steps-to-get-more-hd-from-your-scientific-atlanta-set-top-box/
Aug 03, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony 40V3000 - Ghosting whilst viewing via SCART (Freeview is visable through picture)
have you tried plugging your sky box into another scart socket on your tv set
Mar 11, 2008 | Sony BRAVIA KDL-40V3000 Television
Televison & Video Logo
74 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
