It prints ok for normal text, black and colour, but if I want to print a picture or if I ask it to highlight text or put a box round text it very often (not always) puts blue lines across the page. It even filled a blank sheet with blue lines once! I've cleaned as much as I can clean... any ideas? IF I have to take it apart, where do I start?
SOURCE: Lexmark 3200 colour printer
Dear friend There may be serious problem in the printers mother board which is not sending any signals for the bklack cartridge and should be diagnosed. Pran
SOURCE: Printing mostly blue with lines across page
I have the same problem that you are haveing, I changed the ink ,both black and color, and it hasen't helped any, I wanted to get a new copy and printer machine but I don't want to get one and have the same problem. I have runined a lot of print paper trying something else new. I am open to all suggestons. thanks Ken.
SOURCE: lexmark black cartridge-and printer x1270 not printing black
I have a lexmark 6570 with similar problem. Who can help?
SOURCE: Won't Print!!
Hi again,
For some reason our chat session has ended. Pls accept my apologies for any inconvenience. I will post here should you have further questions. Again, my apologies.
SOURCE: Lexmark X83 printer has streaks printing color pictures (but text is fine)
This is the problem with the cartridge if you brought original Lexmark cartridge you can get it exchanged as the cartridge is nay be defective and the cartridge comes with one year warranty...........................................
Try to re-seat the cartridges in the printer. Open the printer
cover > remove the cartridges > close the printer cover > re-brick you
printer by pulling out the power supply - black box behind the printer where
the power cord is plugged in, and re-plug after 10 seconds. When the printer
turns on, reinsert the cartridges and close the cover. Try to print a document
again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print
cartridge nozzle. Please follow the steps below to fix print quality issues
with your model:
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
