Question about Sansui HDLCD3250 32 in. LCD TV
Won't turn on after unplugging sansui
I change my room around and plugged my sansui hdlcd3250 back in and it won't come on. left it unplugged all night and tried the next day and still nothing, what is wrong with it. i got it as a christmas present and its less then a month old
    New Friend:
Leave it plugged in for about an hour for it to warm up than it will work like normal. I have this problem every once and a while
Posted on Dec 26, 2013
3 Suggested Answers
6ya staff
SOURCE:
rahman1555
rahman1555
  • 5 Answers
SOURCE: Where is the fuse on my sansui LCD 24" tv?
contact the manufacture or open and look inside
Posted on Dec 27, 2012
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: my sansui hdlcd1909 19 in. lcd tv won't turn on. the standby red light blinks once, what can i do to turn it on?
sounds like bad capacitors on the power board. Very common problem. I would look at the caps if any appear even slightly rounded on top they are bad. They should be perfectly flat on top any puffing up means replace that cap.
Posted on Aug 07, 2012
How to reset sansui to factory settings
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jun 06, 2016 | Sansui HDLCD3250 32 in. LCD TV
Will not hold channel memory after tv turned off and then turned back on - have to go through channel memory step each time
Sounds like a main system control memory IC fault. Contact any service technician, or the authorized service center for Sansui.
Gopakumar Gopalan Google
Mar 13, 2014 | Sansui HDLCD3250 32 in. LCD TV
Cover Removal
This is not the same model Sansui, but it is a tv.
http://youtu.be/qMpiC8YL3SE
Feb 12, 2014 | Sansui HDLCD3250 32 in. LCD TV
Iwant reseting tv
If you want to make a hard reset, just unplug the TV from AC wall outlet, and re-plug it back after 20 minutes of so. If you wish to make a system reset, you have to enter its service mode to do this. If you wish to get more details, check the site linked here
Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 09, 2013 | Sansui HDLCD3250 32 in. LCD TV
My Sansui 32 inch LCD TV is not working
The main digital board stopped working. No SCL, SDA. Contact any service technician.
Jul 01, 2013 | Sansui HDLCD3250 32 in. LCD TV
Stand lcd
Contact the autthorized dealer for Sansui.
Jun 18, 2013 | Sansui HDLCD3250 32 in. LCD TV
I have a Tivoli Music System radio/CD player. When it is moved to another room and plugged in at the new location, it won't run! The screen lights up a little, but has to sit for 30-40 minutes bef
The Tivoli Music System must be left without power for a minute (60 seconds or more) anytime it is unplugged, before being plugged in again. If you observe this little rule when changing rooms, it should turn on and be usable immediately (after ensuring it has been at least a minute since it was last connected to power.)
Nov 18, 2012 | Tivoli Digital AM/FM/CD Hi-Fi Music System...
If left unplugged fro the laptop for a few hours, or if the charger itself is moved from room to room, occasionally we get an issue where the green light that indicates power does not show up at all. The...
If light you are talking about is on the power supply itself, you need to replace the power supply. Look on E-Bay.
If the light you are talking about is the AC power light on the laptop, then there are two things that are most likely. First is the power receptacle in the laptop. I have personally seen many of these fail. The other thing is the battery. With the system Off, and power supply disconnected, remove the battery. Wait a couple of minutes and put back in and plug in charger. If it continues to happen then it is most likely the power receptacle in the laptop.
Best of luck, Jim
May 07, 2011 | Ultra Products ADP-65JH DB Ultra Slim...
Sansui HDLCD3250 32 in. LCD TV Logo
302 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
