Question about Sony BRAVIA KLV-40U100M 40 in. HD-Ready LCD Television
First my television had a black screen after a couple of days being turned of i turn on my tv there is some light if the room is in darkness but there still isnt any picture
First there was a completely black screen now if i turn of the light in the room i can see some light on the screen but there is no picture still
    Genius:
  • 1,003 Answers
Turn all the lights off in that room (works better at night) turn tv on shine a flashlight on the screen can u see an image?
Posted on Feb 03, 2013
6ya staff
SOURCE:
Anonymous
  • 208 Answers
SOURCE: Red Light Flashing 6 times
When the lamp fails in this unit, often the thermal fuse opens. The error code is 6 blinks. To replace this part requires a great deal of deal of disassembly.
Posted on Mar 29, 2008
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: Sony KDL-46V3000 Bravia LCD Black screen
Please count Sony KDL-46V3000 standby light blinks as there would be interval of 3 seconds between blinks. Let me know how many times light blinks as its an error code.
Posted on May 17, 2009
Anonymous
  • 67 Answers
SOURCE: After watching the TV this picture goes black, and
I have a KDF E42A10 which is LCD projection TV. If your's is a projection TV then the blinking red light means that the projection bulb needs to be replaced. The access door is on the lower right side, fairly staight forward to remove and bulb costs about $150( varrious sourses can be found online). If yours is a Grand Wega there is a major problem that Sony is denying responseblity for. Check out a report by Googling " MSNBC problems with Sony Grand Wega". Would like to get a clas action going for KDFs.If your TV is not a projection then disregard all of the above and I can't help with your problem.
Posted on Jun 28, 2009
Anonymous
  • 21 Answers
SOURCE: Blank Screen
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Posted on Sep 18, 2009
kb8dns
Rod Wallberg
  • 494 Answers
SOURCE: Last night the screen started going dark, then went out, black
If still under warranty, I would suggest going that way as this is a bad matrix driver....
Posted on Feb 15, 2010
No picture
Sounds like you have a backlight problem. To verify this, turn on the set, dim the lights in the room, and shine a bright flashlight on the screen. If you see a faint picture you have a backlight fault. It could be as simple as a bad capacitor in the power supply, or a faulty inverter board, or in rare cases a bad backlamp.
May 04, 2013 | LG 32LD350 32 in. LCD TV
My samsung turns on, audio is okay but black screen
dim the lights in the room, turn on the set and shine a bright flashlight on the screen. Do you see a faint picture?
Mar 28, 2013 | Samsung LN52B750 52 in. LCD TV
When I turned on my vizio vo37om this morning, there was no picyture, screen is black. Sound is fine
Dim the lights in the room, turn on the set. Shine a bright flashlight on the screen, do you see a faint picture?
Feb 11, 2013 | Vizio VO370M LCD TV
Black screen
If its LCD get the room very very dark and turn on--with a flashlight near the screen look closely at the screen to see if you see a very faint image of the picture or not---Most LCD flatscreen's (not Plasma) use what is called a back light to light the screen--light source.
If a faint picture can be seen that way the light is not on.
Dec 17, 2012 | Sceptre Televison & Video
Sound on but no picture
Is the screen pitch black or a blue/grayish ? Dim the lights in the room, and shine a bright flash light on the panel. Turn on the set, if you see a faint picture, you have a backlight issue
Dec 13, 2012 | Philips 52PFL7403D 52 in. LCD HDTV
I have a Protron LCD 26" TV model#LT26CIPI...The tv was working great turned it off on night and in the morning turned it back on to sound but no picture just a Black screen...when you change channels
Since its a LCD take a flashlight and have the room as dark as possible and with the light look to see if a very very faint image of the picture can be seen or not---many of these sets use a "back light" for the brightness and if that's not on.......
Dec 11, 2012 | Protron PD-DVR100 DVD Recorder
Screaming static
Try turning off different lights near the room or in the room that it is in. Our tv does that if the overhead light in our bedroom is on, it's a room right next to our living room.
Jan 14, 2009 | Polaroid 4226TLMB 42 in. LCD TV
No pic on screen
Double check all of your connections. It appears the video cable is not plugged in completely. Try another monitor if possible to see if the computer is actually outputting video.
Jan 03, 2009 | Dell Computers & Internet
Screen is Black, light I'm in a dark black room black
Same problem as you described. I haven't figured it out yet.
Jul 20, 2008 | Samsung L700 Digital Camera
Ideal settings for Samsung LN-T 4234H
sure, lcd tvs need to be tweeked depending on the light in the room the darker the worse the picture. so try this
from standard:
picture: 85 to 95 %
brightness: 45% or adjust the black of the video to the black of the pilar bars to equilize them.
color: 32 to 38% or until the flesh tones are not so hot
sharpness: low 10%
tint: always to center
color temp: cool1
back lamp ( if avalible) low when lights are dim, high when lights are bright.
the problem with LCD is they don't look so good with dark sceens. the contast ratio is very low. natively 3000:1 aas compaired to plasma or other direct view TVs. the LCD is back lite and the thin materal of the LCD can not completely block the back light from coming thru. there for the complete "black screen" is illuminated "blue". the best thing is to keep the lights on bright in the room for the best picture.
Feb 22, 2008 | Samsung LNT3242H Television
Sony BRAVIA KLV-40U100M 40 in. HD-Ready LCD Television Logo
150 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
