Question about Maytag Neptune MDE5500AY Electric Dryer
My maytag neptune dryer control panel wont light up wont start
    Top Expert:
  • Maytag Master
  • 9,472 Answers
You have a bad control board that will need to be replaced. Here is the part to order.
All parts come with a 365 day, any part, any reason return policy.
Posted on Feb 03, 2013
Anonymous
SOURCE:
Bill Dozier
  • 262 Answers
SOURCE: Maytag Neptune Dryer
is the drum light on while the door is closed?? look on the teck sheet found in the lower front panel for a wiring diagram momery servers me there is a thermal fuse chances are this is bad if you cant find this tech sheet I will look in my invoice book and see if I can find the sheet for it good luck let me know what you find out
Posted on Jan 17, 2008
Anonymous
SOURCE: control pannel wont cut on and dryer wont start
We are having the same problem. We have the Neptune dryer MDE5500AYZ. The control panel doesn't come on. We know it's getting electricity as the light in the dryer is on. Is there a reset button in the dryer?
Posted on May 13, 2008
Anonymous
SOURCE: How to remove a back panel of maytag neptune dryer?
Catriver was right on the mark. Took a little bit of doing but I was able to fix the problem myself within 30 mins, and saved some money. Many thanks. I'd like to expand Catriver's solution a bit.
I found a layer of lint on the inside bottom of my dryer. With the face off of the dryer, it proved to be a good time to vacuum the lint out and reduce the potential of fire.
Posted on Sep 07, 2008
Anonymous
SOURCE: Maytag Electric Dryer - Control panel doesn't light unless door is open
I fixed my own problem...I took the extra 4th wire(green) and attached it to the dryer body...There is a screw with the word ground stamped into the metal above it. This is right next to the panal where the cord goes into. I just unscrewed it and put my cable there and the dryer works perfect.....These things need to have a detailed diagram on the dryer....
Posted on Feb 15, 2009
Anonymous
  • 289 Answers
SOURCE: my maytag neptune electric dryer will not work the
first check that you have 240 coming to unit.than let me know.
Posted on Nov 21, 2009
Maytag neptune
Make sure your light control is turned on. Either turn odometer pin or there is a control left of steering wheel that controls the light level
May 11, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune front load Dryer. Wont start. stuck on .8.8
Open the control panel and you'll find a wiring diagram/tech sheet in there. It will have some troubleshooting tips, may explain the "8.8" in the display. If not, then the control board is probably bad. Here is a link to the board in case you need it.
Jan 05, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDE5500AYW panel lights work but not dryer
inside the control panel is a tech sheet that has some diagnostics on it . there is a membrane button test or something to that effect. I suspect that the start/pause button is the problem and you would need to replace the console w/touchpad.about $130-140 new. there are some used ones on ebay.
May 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag MCE8000AZW Neptune Drying Center. Display
my bottom dryer the light dont come on or when i press start it wont start all i hear is a click...any solutions?
Jan 31, 2010 | Maytag Dryers
Model MDE5500AYW Maytag Neptune Dryer showing code 8.8 and won's start
the circuit in the control. you can get it at
http://www.apwagner.com/index.php?main_page=part_finder
I hope this helps.
Dec 08, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Control pannel wont cut on and dryer wont start
May 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dont start
probley the control panel
Jan 10, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
240 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Gerry Harvey
Gerry Harvey
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
