SOURCE: dayton unit heater
Dayton heaters are a product sold by Grainger. Contact them for a manual.
SOURCE: I need a gas valve for a Dayton model 3E473A wall furnace
you can look for a gas that we go in place of the one you have, try national energy they sell gas valves and should have one to fit your heater , i would change the thermocouple as well .
hope this helps
SOURCE: I need a fan blade for a dayton in wall heater model 2E441
You should be able to google the manufacture and look for a contact us area where you can get a hold of them and order it unless the part is obsolete. They could have a universal replacement.
SOURCE: ned a fan moter for dayton model 3vu36a heater
consult with WW GRANGER. They have Dayton as a line and will be able to tell you whats available from model number. They also have a web site with phone number to their stores. try it w dot com.
SOURCE: I need the the 3 button switch on a dayton model
Hi, what you are going to have to do, is remove the switch, mark the wiring so you know where to terminate and take the switch to a local appliance parts house. write down and take the unit model and serial #'s down also as they may have to match it with an aftermarket type normally closed switch that's if they can't find the OEM switch. Sometimes, you can get away with going to a air conditioning wholesale only parts store and you can pay cash for the exact replacement. But yes, it will have to be a parts house that deals with this equip. I hope this has given you some direction as to you're question. Sincerely,
Shastalaker7
