ThinkPad T23 2647
Manufacturer - IBM
Series - T Series
Subseries - ThinkPad T23
Machine Type - 2647
1) Remove ALL power. Remove the AC adapter (Charger), and Battery.
2) Battery removed, Battery Compartment facing you.
Look at the right inside edge. There is a small plastic cover inside the Battery Compartment.
Remove the one Philips head screw, then remove the cover.
Backup battery, CMOS battery, or RTC battery. SAME/same.
(Real Time Clock battery)
Also, here is the Service Manual,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-ibmlenovoDrop down to the 8th line. (ThinkPad T20. T20 in blue)
Scroll over, and left-click right on - T23
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name, (T23), it may take up to 30 seconds, before the first page comes up.
Start on Page 66. Backup Battery is on Page 67.
OR,
In the Bookmarks menu to the left, click on -
1) The + sign to the left of -
ThinkPad T20, T21, T22, and T23 series.
2) The + sign to the left of -
Removing and replacing an FRU.
(Field Replaceable Unit)
3) Left-click right on - 1010 Battery Pack, and 1020 Backup Battery.
Nice to have when you are going to clean that puppy out.
(BUY, and wear an ESD wrist strap. Connect it's alligator clip to a good ground source.
Average price is around $3 to $6)
Also nice to have to upgrade the Processor, and a myriad of other things.
Regards,
joecoolvette
Yep have now reset date and time settings many many times!
I am now down to trying to find how I can check the battery supply is fed to the chip, but have no cct diagram!
FWIW I dual boot fedora9 and XP but that should not be relevant.
Thanks
