Question about Tektronix Office Equipment & Supplies
Tektronix 5440/R5440 #070-2139-01 Instruction Manual,3209E-1
Oscilloscope
WHAT SHOULD THE VOLTAGE BE ON TPS ON 1996 CHEVY BLAZER
Please read this:
http://www.automedia.com/Throttle_Position_Sensor_Adjustment/ccr20040701ts/1
Jan 21, 2013 | Tektronix TPS2024 200MHz 4 Channel Digital...
Manual for a Garrison Portable air conditioner
I have uploaded the manual for my model 5440 (3-in-1) here: Garrison 5440 Owner Manual
Jun 16, 2012 | Heating & Cooling
TDS2024 will not connect to USB stick of greater than 512KB. Firmware was upgraded to the latest .11 firmware with no effect. It is supposed to handle up to 64GB with this revision.
Do you know if that unit supports NTFS partitions? That typically requires a licensing fee to Microsoft. You could try formatting the drive as FAT32 and see if the Tektronix recognizes the full size.
You can format any USB 4GB or smaller with the normal Windows format utility. However, if you have a flash drive larger than 4GB you need a third party utility. Paragon Partition Manager has a free version that should do the trick for you. There are others as well, including a great one called SwissKnife that is free as well.
P.S. - I just posted a question specifically for you to help (if you can). Search PMH880s. Thanks!
Feb 05, 2011 | Tektronix TDS2024C 200 MHz, 4 Channel,...
Tektronix scope TDS 320 GOING,BUT NO COMMUN .VIA PANEBUTTONS ?
The Tektronix TDS series are notorious for the electrolytic caps drying out. They are SMT components and hard to replace if you do not have the proper equipment. Replace all of these on the main board ad all of your problems should be resolved. Good Luck!
Mar 20, 2009 | X-10 PROB100 100M Hz Oscilloscope Probe...
I have a Tektronix Phaser 540 with an error code 32 when I powered it up. Can you tell me what this means?
This is from the 560 manual hope the codes are the same. The 560 manual states : Accumulator belt cleaning blade movement error.
1. inspect the cleaning blade{located on the imaging unit,along the bottom of the green OPC belt. Is it flipped up? If you cannot flip it down, replace the imaging unit.
2. Inspect the wiring harness leading from the cleaning board to CN18 of the engine control board.
3. Replace the cleaning board.
4. Replace the engine control board.
If the above info does not match your model call :
(800) 833-9200 Press 3
(503) 627-2400
Aug 21, 2008 | Tektronix Office Equipment & Supplies
Eclipse 5440 Manual Needed
I had the same problem until a minute ago:
1) press and hold the display button
2) using buttons 1 thru 4 set the time while holding the display button down. ( buttons 1 and 2 adjust the hour, buttons 3 and 4 the minutes...
Good luck
Jun 12, 2008 | Eclipse 5440
61 people viewed this question
Top Tektronix Office Equipment & Supplies Experts
Vincent G
Vincent G
STEVE
Vuk B
Are you a Tektronix Office Equipment and Supply Expert? Answer questions, earn points and help others
