The spin cycle leaves the clothes wet & excess water in the washer tub
Go to an autoparts store and get a radiator hose pinch off plier pinch off the top tub to pump hose so that the water does not run out when you remove the water pump hose clamps; then remove the pump or, open it up to remove the impeller (fan) obstruction if that is the problem
SOURCE: Kenmore washer - water is emptying from tub but clothes are not spinning dry
replace door switch.If the computer thinks the door is open, it will not fast spin as a safety precaution.
SOURCE: washer doesn,t spin
two possibles here, if the drain pump is clogged and therefore the unit will not go into a spin. After pumping, it will error out and just shut off. If the pump is ok, then the motor control unit has failed.
SOURCE: excess water in clothes after spin cycle
Unblock the outflow pipe from the machine that goes into the sump under the sink. (have a pot ready for water overflow) This will help drain the water. If the spin cycle is making a screetching sort of noise then it is possible that the carbon brushes will need changing. This affects the spinning if the brushes are worn.
SOURCE: model 110 washer will not go into a final high speed spin.
is it top load or front loader kenmore what
SOURCE: kenmore washer spin cycle doesn't leave clothes dry
SOUNDS LIKE THE TRANSMISSION IS NOT ALWAYS SHIFTING INTO HIGH SPEED MODE,TRY A MED. SIZE LOAD AND SEE WHAT THAT DOES,TRANSMISSION MIGHT JUST BE GETTING OLD WHIH IS NORMAL-MIKE
First off, thanks for the replies. mmm, There's no screeching noise. I think it may just be a clog. I've got the unit pulled away from the wall, unplugged & easy to get to. Now, can someoe tell me how to get to the drain, or pump, or to anywhere that there might be a clog?
