I have a UN19D4003 and it comes on by itself, runs for a few minutes, then shuts down. Sequience is shorter each time. Plug it in, it's starts up, runs for 2 minutes, shuts down. Few seconds later starts back up, runs for a minute, shuts down, now wait a bit longer it repeats, but runs shorter each time. Doesn't seem a capacitor would do this... The auto start up I mean.. Then again, I am here asking you!
SOURCE: Samsung 26" LCD TV
You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
SOURCE: freezes turns white then turns off then back on
IF YOUR IMAGE IS ALL WHITE YOUR LOGIC BOARD IS DEFECT BUT IM SAD TO SAY DO NOT REPLACE THE LOGIC IT WILL ONLY TEMPORARLY SOLVE THE PROBLEM THE PANEL IS OVERLOADING THE LOGIC BOARD PANEL IS BAD
SOURCE: 40 inch samsung, little over
hi there.your set needs four new capacitors fitting on the power supply.they are grouped together,if you take the back off,you will see they have domed out on the top,and may be leaking brown fluid.if you are reasonably handy with a soldering iron,replacement is dead easy.caps are only a few pence each,take note of the polarity when changing.this is a VERY common problem.
regards,steve.
SOURCE: have a 55 inch samsung lcd tv and it keeps turning
samsung plasma just started doing the same thing, but turns itself on & off only seconds apart, so I can't even get a picture. Another site gave this advice.
Press D.menu
select SETUP icon
select SYSTEM
select SOFTWARE UPGRADE
select STANDBY MODE UPGRADE
select OFF
SOURCE: I own a 50" samsung plasma, model hp-t5054. Last
you have a defective module on your board,about 1x1 inch black have a technicien appraise only if the service is free
Thank you for your comment. Question is, Is it truly the power side? When I disconnect the tuner side circuit, which removes all other functions & circuits, and power up, I light up the screen. Yes it's the back-light, but it doesn't shut down. First; should the back-light be coming on? Second; If so, then I think it's tuner side that has the short.. Third; If the back-light should not come on, then diffidently the power side.Cap's look good (tested), diode's are good (tested), transistors are good (tested)... Suggestions? Comments? Help??.
