I can check this website, there is fuse box diagram and description for Honda Civic (2010 - 2011)
Honda Civic 2010 2011 fuse box diagram Auto Genius
SOURCE: fuse diagram for 1996 honda civic
try this link... let me know if this is what you needed... http://img530.imageshack.us/img530/8770/9600civicfuse98civicexatb2.jpg
SOURCE: Need Fuse diagram 2000 honda civic
I found a copy of your FUSE BLOCK DIAGRAM.... But I cant fax it to you ..So I will send you to the web site where I found it..Go to http://www.autozone.com Register your car, then click repair, and look for electrical Diagram..
SOURCE: I need a fuse diagram for the interior fuse box on
If you have Adobe reader, look here:
https://techinfo.honda.com/rjanisis/pubs/om/CV0404/CV0404O00186B.pdf
Hope this helps you.
SOURCE: where is the fuel pump fuse located on 1994 Honda
Fuel pump is in the tank, there may be an access panel under the back seat area. One thing to check is the Main Relay. Ususally up under the dash, Left Dash area, I dont have a diagram, but you will need one to find and verify the relay operation.
