Curtis CM13102 13" TV Logo
Posted on Feb 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Old Curtis CMC13003 will not display DVD picture
It is a TV/VCR unit I bought in 1990. There is only two AV jacks that seem to be Audio (white) and Video (yellow). But most DVD players have 2 Audios (white/red) and a third Video jack. Do I need to find AV cords that have only 2 (white/yellow)? Is there such a thing? I have tried channel 3 and all display options provided by the remote to see if there is a tricky way to watch DVD on this unit. Or is it frankly just two old school to accept a DVD player?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 19, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
140
Points
The white audio plug goes to the video in
Anonymous
Level 2:
  • Expert 56 Answers
  • Posted on Feb 03, 2009
Anonymous
Expert
Level 2:
Answers
56
Questions
Helped
19240
Points
162
Radio Shack has a Y adapter to hook up the 2 audio wires together RED/WHITE are audio. 2 females to 1 male Y adapter
How do I hook up my Toshiba DVD player to my old Daewoo Tv /vcr combo
what inputs does the old Daewood / VCR combo use is it RCA and Video cable on an AV input? How many Av inputs are there in TV ? Does the DVD player have AV out audio out (Yellow) RCA (Red and White). If you do not have enough AV inputs on the Tv use an AV switch box . and Switch two AV RCA inputs /DVD and VCR and into one output to the TV. You may be able to feed the AV out RCA out into the VCR AV in and switch the input on the VCR.
1helpful
The player does play the dvd's and everything but the picture wont show up in my television. I already connected the RCA connectors into the television and the player but still no picture. Please Help.
Assuming you used the standard YELLOW-WHITE-RED RCA cable, between the unit and the TV, the colours of each of the plugs should match both the outputs on the rear of the unit and the respective inputs at the rear of the TV. The TV must also be on an AV input 'channel' to receive the connected unit. (for example, AV1 or VIDEO 1)
Try changing the RCA cables - just in case the ones you currently have are defective in some way.
Being a combo unit, there should be a DVD-VCR common output on the rear - using RCA cable, the YELLOW is video, the WHITE is left channel, the RED is right - these MUST match the input on the TV, and the TV AV input must be selected in order to view the pictures and audio from the unit. To enjoy both VCR and DVD, using the RCA connection, the common output on the rear of the combo unit is recommended.
Better quality video is possible using S-Video cable (available from electronics stores such as Radio Shack etc. but this does not provide audio; you would still require RCA RED-WHITE cable for that, and your TV may not have S-Video input). Your TV may have a TV/AV button on the front - select the correct AV 'channel' with that if necessary.
It makes sense to check everything twice before assuming anything is broken.
The VCR works fine but I only get audio with the DVD
  • Are you using an AV cord between your VCR and TV or a standard coax? If you are using a standard coax then first make sure the tape is functioning properly. Next try a new coax and if the problem persist there might be an issue with the coax output/input on the VCR or TV itself.
  • If you are using the AV inputs (red,white and yellow) you want to remember that the red and white are for audio and the yellow is for video. So in this case you want to
  1. Make sure the tape is functioning correct. Old tapes that have seen their better days will produce audio but no video and vice versa.
  2. Check the connection of your yellow AV input (audio). Make sure it goes from the same output on your VCR to the same input on your TV as the audio cords are running to.
  3. If this checks out then try a different audio cord and see if this fixes it.
  4. If not then try using a different output on the VCR and input on the TV all together.
  5. At this point it is possible one of the AV audio jacks are bad either on the VCR or on the TV.
Regards, Tony
CANNOT SUCCESSFULLY HOOKUP A DVD/VHS TO MY VIZIO MODEL NOS. DVD-v2000 25W
I was the person chatting with you earlier on, before the chat was disconnected. My system went off and I'm sorry about that.
I'm responding here in order to make sure your problem is solved.
LAST QUESTION THIS IS A DVD/VHS DUAL UNIT AND IS CON NECTED WITH THE wHIT rED AND YELLOW TO FROM THE COMPONENT AREA TO THE BACK OF THE TV
You can do the connection by using two different methods: (a.) you can use the component method or (b.) you can use the AV method.
Using the Component method: The component is a combination of red, green and blue wire connection which brings video or display.This three must be connected for you to have a display of your unit on your TV.
Connect the Red, Blue and Green wires respectively to their appropriate places on the TV, then the other part on your DVD/VCR. Note that this connection will only bring a display and no audio. You will have to connect the red and white wire from audio out of the DVD to audio in on the TV.
Once you have successfully done the connection, put on the DVD/VCR and your TV, then press "source" on your TV remote and select component 1 or 2 for you to get a display.
B. Using the AV connection: The Av connection is using the RCA wires which is yellow white and red, just as we discussed while chatting. Connect the Yellow, white and red wires, from the TV to the DVD/VCR, the select AV on the TV remote.
Unlike the Component which its video connection is red, green and blue for display, the AV is only Yellow for display. I hope you under stand this.
Please try to follow my explanations and let me know, if you don't understand and I will explain further.
It was nice chatting with you.
Take care.
Do not know how to install to cable box tv
Connecting this up will be easy. What you do is get a yourself a set of the right, for your setup, cables. That uses EITHER one of the formats, of these described, below. You will need, either, a THREE way Cable, or three separate " Coaxial Cored" Cables with RCA PLUGS on them. ColoredYellow, (Video) Red, & White. (Audio) AV. OR If you have SCARTConnection Sockets, it's a big Black Socket at rear of unit(s), you get aSCART Cable.& It's all inside. Now some units, use a standard calledComponent Video, that uses, a Green, Red, & Blue Plugs. Now, with the Component setup, you will also ,need, Two more Cables, for the AV Audio. these are, Red & White.(So with Component Video there are 5 Cables/Plugs in all). In any event ALL Cables go Color to Color, at each end, plugging into the corresponding Colored RCA Jacks, on either machine, or VCR or TV. Now if you have SCART, then it simply plugs in only one way. It is that simple. So connect up with the leads your set uses, and select the correct "Input" from TV/Remote, it is NOT on a "Channel" it will be on AV, AUX, and Press "Play" on VCR/DVD whatever.... should be all go.
Zenith TV has no place for yellow, red, white composite plugs
This TV doesn't have an AV input, so there are no input jacks other than the antenna connector. If you want to connect a device that has only AV outputs (your red, white and yellow plug) you will need an RF converter. This will take the AV signals and convert them to a channel 3 or 4 signal you can tune in on the set.
But since you don't seem interested in spending any money, you'll probably not like to hear that the converter runs around $15 most places. Take heart, there is an alternative. Find a VCR (if you don't have one already) that has an RF output. Many of the the newer DVD/VCR combos only have AV outputs. You're looking for one that has an "out to TV" threaded connector on the back. These units already have an RF converter built in. Connect your AV plugs to the line in jacks on the VCR and switch to that input, and you can use your video game or DVD player through the VCR.
2helpful
I have a Curtis Mathes combo tv/vcr Model CMC13003
I am having the same problem you find out anything?
No picture on VCR/DVD
Try to use AV cables they work better than RF cables in my opinion. AV out to TV in works everytime.
Getting a dvd player to record vhs to dvd
The RF converter takes the Red/White/Yellow as INPUTS and converts them to either channel 3 or 4. You need to go the other way. You need a tuner or another VCR to convert from RF (channel 3 or 4) to a standard AV signal (Red/White/Yel).
Dan
Top Curtis Televison & Video Experts
 Grubhead
Grubhead
NOEL
NOEL
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
