Question about HP Compaq Presario 2200 Notebook
Hi HP Compaq Presario 2200 PC Notebook Usb problem usb not work any idea about solve this problem usb & sound problem & touch pad cannot be move
  • captainjerry Feb 12, 2009
    I am going into the BIOS Setup (F10 at boot) and see if the USB ports are turned off, and if the touchpad is also turned off. But first I need to remove the CMOS battery because someone put a Password in it.
    Scholar:
  • 38 Answers
Dear Mr. Amr, (if this solution doesnt solve your problem, without rating the solution, please leave a comment and i will try to resolve your issue.)
Dear Mr. Captainjerry,
For your issue, please find attached the service manual for your laptop at this link. (*read complete email before clicking this link)
http://www.hp.com/ctg/Manual/c00226047.pdf
BUT,
If your laptop uses security chip protection, please continue reading as removing the battery won't help ... nor is there a reset jumper. If this model uses a Security Chip for access protection => once a password is set for BIOS access there is no way to reset it if you don't know the password. It will require a new security chip (which requires extensive soldering/desoldering skills and equipment, as the security chip is wave soldered to the board) or a new motherboard. You'll need to have the laptop serviced at an HP repair facility.
If you're comfortable with your soldering/desoldering skills, you may be able to buy the security chip here http://www.pwcrack.com/security_chips_compaq.shtml
Although they may not list your specific model, they can often get the appropriate chip if you give them a call.
Security-chip enabled laptops have EXCELLENT security => they're designed so that if you set a password your data is thoroughly protected against anyone who doesn't know the password -- including YOU.
The good news is that's great protection -- you can be sure that if the laptop was lost or stolen nobody can access your data. The bad news is that if you forget the password you're out of luck -- you also can't access the data. There's simply no recourse except to have the laptop serviced at an authorized repair facility ... they'll likely require proof of ownership; and it's not an inexpensive repair.
Hope that was useful. If yes, please rate the offered support.
Regards,
Techno-Geek.
Posted on Apr 16, 2009
Mouse stopped working on Compaq Presario CQ57
The Touch pads the Mouse Pointer uses is pressure sensitive and sometimes without warning WILL fail to work I own a CQ50 And Have a On Off Option for the mouse pad Yours does not Apparently it Is a bad sensor If you have a warranty send it in If not best suggestion for you is buy a USB mouse and use it Otherwise trying to have it replaced without a warranty can be costly.
Feb 03, 2012 | HP Compaq Presario CQ57-229WM Notebook PC
Compaq Presario 2200 Severed touch pad cable. When I attached mouse says it needs driver. Is there a sight or does anyone know which are the main keys to control selector without touch pad or mouse ??...
Arrow keys, Enter, Tab, and the Windows key are the main control keys. However, Windows should recognize any generic USB mouse you plug in, and automatically install the drivers for it.
Mar 24, 2011 | Compaq Computers & Internet
I am using Compaq presario CQ56 and my left click is not working in the touch pad. However when my system starts and asks for a password the left click works fine...but when i enter the password and after...
and old CQ56, super old that.
no oS stated, XP the virus magnet?
who asks for ps bios password or windows login screen.?
did you remove all other usb devices, fur SURE MICE?
id say virus infected.
then bad pad driver,
in device manager, see that pad there, click update
do so , online.
C56 tells me nothing the model has numbers at the end
if still running HP windows,(not hacked with MS disks)
the drivers for HP pad are at HP
but i can look for you lacking that a full model number.
here ill guess to teach you how HP works
CQ56-100us (us means us keyboard there)
ill pretend you said XP 32bit
and land here
then got the driver for XP here called.
Synaptics TouchPad Driver for Microsoft Windows XP
15.0.18.0 Rev. A (get it load and and use only that if i guessed right.
https://support.hp.com/us-en/drivers/selfservice/compaq-presario-cq56-100-notebook-pc-series/4247498
Jul 03, 2017 | Compaq (153515-001) Touch Pad
Hi! i got a mobile presario compaq presario
First check with windows explorer if the devise is shown. If not check with devise manager if all usb ports are enabled (control panel-Hardware and sound-Device manager). Hope that helped!
Mar 22, 2010 | HP Compaq Presario C700T
Describe your compaq presario cq60 touchpad not
after rebooting my Compaq Presario CQ60 laptop the touch pad does not work and I have to use a plugged in a mouse
Mar 09, 2010 | HP Compaq Presario CQ60-249US Notebook
The cursor moves but the clicking doesn't work
Re-install drivers from vendors site, if still no go a mobo fault.
Buy USB mouse and use instead of.
Jan 22, 2010 | HP Compaq nc6000 Notebook
Hi my name raji I have a laptop ... compaq presario v5000 wel its touch pad scroll is not working what can i do
their is only one solution for compaq v5000 as you have to buy a usb port small mouse.
i mean that you have to purchsae a new mouse.
George_raji
i want to ask a question that wheather you touchpad has been coloured off by using it.
if yes than tell me yes?
Jan 03, 2009 | HP Compaq Presario V5000Z Notebook
Compaq presario V2000 notebook freezes
Did you reset your BIOS? sounds like your usb is not configured properly
Jul 25, 2008 | HP Compaq Presario V2000 Notebook
Installing a wireless card in my presario 2200
The easyest way would be to buy a USB wireless adapter.
You just plug it in install the software and thats it.
I'm useing a TPLINK USB adapter, it cost me 20 €
You can also use a internal card, Mini pci most likely. very simple to install also but you might have signal - antenna problems. But this tplink has worked very well in my home and in the city.
May 17, 2008 | HP Compaq Presario 2200 Notebook
HP Compaq Presario 2200 Notebook Logo
337 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Toby Lee
Toby Lee
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
