The power is fine. The cables are solid. Now what do I do?
SOURCE: al-1540 only scans, wont print says-data could not be sent to pri
it seems that the computer was trying to send the data to the printer through the wrong port. i went to the control panel in windows xp, and selected printers and scanners. and added a new printer (manually) as al-1540 cs on usb port 2. it alerted me that the software was not signed, i proceeded anyways. it asked if i wanted to keep the original printer , i said yes. and the test page printed away. so i would suggest people with similar problem to keep adding multiple copies of the printer again and again on usb ports 1,2,3... etc till it prints the test page. use the copy no. indicated in the printed test page to do all your print jobs in the future.
SOURCE: Flashing ''4'' and ''H'' on the printing screen
Press [exp 1] [c] [exp 1] [c] [1] [4] [start]
SOURCE: how add developer to sharp ar-208d
Set-up for this copier sure isn't well-documented. We just got ours working today, by following the instructions here: https://www.businessneedz.com/Manuals/ar168s_setup.pdf (yes, it lists a different model number, but the instructions worked, and were linked from the ar-208d product page from the supplier)
SOURCE: sharp AR-C260M stuck on initializing print
Your AR-P16 or P16N print controller is broken or needs a firmware flash.
