Is there anyway to force this calculator to give me the result of a radical notation calculation in radical notation form? When i do the 4th root of 243 I get a decimal, instead of it simplified in radical notation.
This calculator can show the results in radical form if it involves square roots. The 4th root of 243 is 3 times the fourth root of 3, which unfortunately is beyond the calculator's capabilities to display in radical form. Try taking the fourth root of 3 (or equivalently, the square root of the square root of 3) and you'll see the calculator display the result in decimal.
SOURCE: simplifying radicals on fx-115ES
If your calculator is SetUp for Math Input/Output (MATHIO), a result that gives a radical will remain in radical form. If a radical appears in a denominator the whole expression is rationalized: Any radical left is put in the numerator. 1/Sqr(3) is displayed as Sqr(3)/3.
SOURCE: on my casio fx-82au plus calculator it won't
The capability of these calculators to handle irrational numbers in radical form is limited to square roots. Roots of index other than 2 are always displayed in their decimal representation.
If the calculator IO mode is set to MathIO, square roots will be displayed with the radical symbol. More complicated expressions with square roots might not be preserved and will be given as decimal numbers.
