My Stairmaster 7000pt seems to work normal up to about levels 10 or 11 then looses all resistance and goes faster and faster until you can't keep up. Any ideas?? Thank s for any help
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
This could be caused by worn alternator brushes. The following link will take you to a video on testing the alternator. If the alternator checks out, you may be dealing with a faulty display console.
Video about Performing Jumper Test on Stairmaster Alternator
SOURCE: When my wife uses stairmaster
hi
just check the speed of unit if she goes faster than when she was on level 17-or 19 it is ok
if not calibrate the tension but i think it is always feels like this
let me know
SOURCE: My Stairmaster 4600CL is stuck
What has happened is the control panel is bad and you need to replace it.
Good Luck
SOURCE: my stairmaster 7000pt step is grinding and
most likely your gear reducer (transmission ) has stripped and wii have to be replaced . call glide fitness products in santa ana california 1 866 637 4600. they will sell you a new one for about $180 or send in your old one and they will send you a rebuilt one for about $75 note shipping is extra
SOURCE: stairmaster stepmill 7000pt all pwer
console could be defective try to diagnose it by entering diagnostic codes from your manual
also check the mechanical parts inside , a hinge rod could have slipped out and has pinned the entire stairs
