I just bought an older snow blower for a lawn tractor .The problem is mounting the support that goes under the tractor,it ok in the back ,where it bolts in the trailer hole. But there's no place to mount the front of it to the tractor.It's a sears craftsman, snow blower model # C151610610,serial# 973164 .The tractor is a new 22hp Craftsman.
SOURCE: CRAFTSMAN SNOW THROWER DRIVE WHEELS WILL NOT MOVE
well if it is a walk behind style it could be the drive is out of adjustment, also craftsman were famous for the cable mounts bending and that will throw them out of adjustment. follow the traction drive linkage down to the base of the blowe and there should be an adjustment, or it will be under the belt gaurd or even on the handle on some.
SOURCE: snow blower lever is stuck....won't move to
sounds like the cables are loose retighten all cables...good luck
SOURCE: Does anyone know where I can get the 5-1/2" V
Try your local power equipment dealer. They usually have many brands in stock and may be able to match one up with a different manufacturer if they don't carry your brand.
SOURCE: the dumb aholes at sears
Lol, Sounds like sears ;)
I looked a a few cross reffs at sears and could not find it.
I might recommend a piece of 1/8" plate. Mark your holes and bolt it on after an hour with a drill. It will be better and more functional.
Good luck
Joe
