Question about LG WM1814CW Front Load Washer
LG Tromm Model # WM2075CW doesn't drain - water everywhere!
I have the LG Tromm Model # WM2075CW. About a week ago, the water failed to drain and began leaking from the bottom of the door where the clothes are loaded. My first steps in troubleshooting were to check all hoses (the one that drains from the tub to the pump housing, also the one that goes from the pump hosing to the fitting mounted on the back of the washer and lastly the hose that goes from the fitting to the drain pipe. I also removed and cleaned the filter located on the front lower left of the washing machine. Since I found no blockage in the hoses or the pump housing (and was able to **** the remaining water from the washing machine using my shop vac) I figured the pump was bad. This has been removed and replaced but the washing machine is still overfilling and water is draining all over the floor. I assume that the control panel is bad but am hoping that there might be a water level sensor that is bad. Is this a possibility? How does the drain cycle get triggered? Is it on a timer as part of the cleaning and rinsing cycle or is there a sensor that could be bad? any help or information would be greatly appreciated.
Thanks in advance for any assistance.
Ed
  • 1 more comment
  • nygiants11 Feb 07, 2009
    Unfortunately, the troubleshooting guide only directs me to rectify issues associated with a blockage in the drainage system. I checked all hoses and even replaced the pump that pushes the water out of the washer but my problem still persists. I tried calling the lg 1-800 support number but they were also only able to assist with issues related to a blockage or bent hose. However, they did give me numbers of a few service centers in the area and I am hoping to talk to a technician on Monday morning for additional direction. I will post a follow-up comment for others to use as reference if I am able to get some useful information.
    I think my issue is connected to the control panel or a water sensor (if the machine has one). It appears that the drainage pump, the one I just replaced is not being triggered to turn on and push the water our of the machine. Any additional input would be greatly appreciated.
    Thanks Again,
    Ed
    Thanks Again,
    Ed
  • nygiants11 Nov 14, 2009
    Thanks for all the feedback and assistance. I finally broke down and called a professional to come and fix the washing machine. It turned out to be a hose inside the machine that had a tear and needed to be replaced. Unfortunately, I was at work when it was fixed and my sister-in-law couldn't give me specifices as to which hose or how it was accessed. Good luck to anyone else that is having problems and just say no to LG if given the chance.
  • 3 Answers
Not sure if this will help but .... Take the drain filter out and look behind it with a flashlight. We had this problem and discovered a metal bottle top lodged in the hole which goes to the pump. Removed the bottle top easily and the machine works fine.
Posted on Mar 25, 2009
    Scholar:
  • 99 Answers
This is joyce
I hope you have not been waiting long for this answer, go to the website lg.com dowload your document on your washer put in your model # first and then it will give you all the info you need on that machine even trouble shoot it and codes. I hope this helps.
thanks,
joyce
Posted on Feb 07, 2009
  • Anonymous Feb 07, 2009
    This is joyce
    thanks,
    joyce
6ya staff
SOURCE:
I need to force my lg tromm to drain
My LG Tromm washer has a small door on the bottom left hand side on the front of the washer. Open the door and you will find the drain filter and a stoppered, small rubber tube. Position something to capture the washer water under the small rubber tube and pull the plug.. This will drain all the water from the washer.
Aug 01, 2014 | LG WM1814CW Front Load Washer
Replacing the pump in my LG tromm
cheaper to check for a problem in the impeller first as the pump motor seldom fail but there are problems with items jamming the impeller
Oct 29, 2017 | LG WM-2277HW Front Load Washer
Washer WM2075CW -The dispenser is stuck, only pulls out aprox 1/2
Yes you are correct, fabric softener dispenser is culprit. Search on this site for solutions. Issues and solutions have been posted often.
May 04, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Water not filling machine and do not see suds but it does sound like its filling up. Hear it filling but do not see any water
Not sure of your model but the larger LG front loaders have 2 pumps, 1 for drain and other to pump water up over the clothes through a fitting in the top of the door rubber seal. If something is stuck in the pump or the pump has failed the clothes wont get wet.
Apr 19, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG TROMM wm2075cw gives an error of OE... and won't spin out the laundry.
Washer has a filter, at the bottom left handside of washer, which needs to be cleaned out. Refer to manual. Worked for me :)
Nov 27, 2009 | LG Washing Machines
LG Tromm WM2075CW will not spin. I've done
Check first if repositioning the drain hose would help solve the problem. If your unit employs a drain valve, have it checked out. It has a solenoid or a small motor that opens and closes the part. Check as well the drain pump if it is running or no power is being supplied. Have the wire checked to see if there are loose connections.
Aug 27, 2009 | LG Washing Machines
LG Tromm WM2277HW during high speed spin makes noise
I had exactly the same symptom...grinding noise only during high speed spin cycle.
I took the top and back panels off to see how the drain hoses etc. connected. Not wanting to take it apart further, I eventually just took the washing machine outside (I knew I was going to be dealing with water!), pulled the debris catcher front side bottom, and let rip with a garden hose inside the drum with the catcher out (leaving an open drain that could flow unimpeded).
Water flowed quickly out of the open drain, and lo and behold, a small drill bit came out with the water flow. This bit, presumably had gotten through the drum grating, and was resting on the bottom of the housing, scraping and grinding when the drum was spinning.
Aug 16, 2009 | LG Washing Machines
LG WM1814CW Front Load Washer Logo
2,274 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
