Says paper jam but there is not one
SOURCE: epson jammed paper
Check for the compatibility of the paper you're using by visiting www.epson.com and selecting your region. Also, I might add that make sure paper is properly loaded.
SOURCE: smearing my printouts
Possible that the printhead got affected when it jammed the paper.
Take all the cartridges out and put them all back into the printer. Let it charge like it normally does.
Print a nozzle check pattern if you see any gaps or breaks or any missing lines on the pattern, clean the printhead.
SOURCE: EPSON R 300 SAYIN PAPER JAM WHEN NO PAPER JAMMED
Make sure that the paper path is completely clear and clean the paper sensors with a q tip. They get very dusty!
