Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451 Logo
Posted on Feb 07, 2013
Bl1815 wont charge - Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451
theoisle
Level 1:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 55 Answers
  • Posted on Jan 20, 2015
theoisle
Contributor
Level 1:
Cheetah:
Answers
55
Questions
0
Helped
59725
Points
88
It might be possible that your 110 V adapter cannot handle the charger power requirements. Make sure the adapter rating exceeds the power requirement of the charger. They both should be labeled in watts.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 13, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
531
Points
I bought a new makita cordless drill in united states of america brought it home to the republic of ireland got a 110 adopter to recharge the battery but it will not hold the charge would it be the flight home have wiped the batterys what do i do?
1helpful
I'm using a Makita DC18RA rapid battery charger with my BL1815 Li-Ion battery. I cant' seem to get the batteries to charge. How can I isolate the issue and fix the problem?
You batteries may be dead. Any battery can only take so much charging before they quit on you. If your charger shows that it is charging and it still has not charged overnight, it is the battery. You can search on YouTube how to "recharge" Makita batteries when this happens. The Makita battery charge has built in diagnostics that will tell you if a battery is bad or not, but will not tell you if the battery no longer has the ability to charge.
What does the 24wh mean in a makia battery bl1815 18v 24wh
It is a measure of the energy contained in that model of battery
24Wh means that it could deliver 1W for 24 hours, or 24W for 1 hr or that it is able to store 24 x 60 x 60 J or 24 x 3600 / 4.18 calories.
12.February.2015
Feb 12, 2015 • Drills
Makita BL1815 battery
open battery case and look for corrosion clean with baking sodas
When putting the battery in the charger the red and green lights flash indicating a bad battery, cannot charge battery.
Have you tried just waiting a few minutes, it might start to charge anyway. But if not, is there some reason you would assume that you don't have a bad battery? There are lots of bad Li-Ion batteries.
The Makita BL1815 battery will not charge, lights flash red/green, indicating bad battery. I replaced one open cell with known good cell, charger still reads bad battery although I can charge from an...
tried it a few times. got the charge up to around 13.9 and it still wont charge. i dont understand, because the battery isnt that old to begin with. thanks for the suggestion.
2helpful
2answers
Battery compatability problem. I bought the saw and batteries separately and now find that the BL1815 LXT Lithium batteriesdon't fit in the BSS610Z LXT 18v Lithium saw. I also bought the charger. Is there...
The two are not compatable. The battery chargers are also not compatable. The main difference between the two batteries is the Amp Hours. The 1815 is only 1.5 Amp Hours and the 1830 is 3.0 Amp Hours. The slide pattern for the batteries are different respectfully. You will need a DC18SA battery charger to charge the 1830 batts.
Top Makita Drills Experts
Sean Wright
Sean Wright
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you a Makita Drill Expert? Answer questions, earn points and help others
