When watching HD channels on my 50" plasma the sound quality is really low. If I switch to the original channels the sounds is loud and what I would expect.
when watching HD channel the sound is low when I change it to the regular channel it is really highwhen watching HD channel the sound is low when I change it to the regular channel it is really high
You can't post conmments that contain an email address.
Most of HD channel broadcast in 5.1 channel sound. Regular channel broadcast in 2.0 channel sound. You TV only have 2 speakers so you will expect the sound will be low compare with the regular channel.
I ended up installing a stereo graphic equalizer/ sound limiter from Radio Shack. I use the ear phone output go into the equalizer / sound limiter then go into a speaker system. You can adjust the EQ and limit the volume. I also had problems with load portions of movies, commercials and low/ high audio. This also allows sound enhancement with some buttons on the EQ. It is usually used in sound reinforcement as in Band and public address systems also higher end stereos systems. you will need a set of powered speakers for this solution so the EQ has somewhere to go to.
Appears you are getting a weak signal at the channel 9 frequency. If you are using a signal splitter, try replacing it with an amplified unit since splitters always do the deed but they can and will reduce signal strength significantly.
Also remember that digital signals are not like the older analog ones that they replace. They are not subject to ghosting but are weaker and susceptible to all sorts of interference such as a leaf, rain, etc. Your antenna is good.
You also might try raising the antenna. The higher it is the better it works. (use some wire to further support additional height) Why do you think transmitters are so tall?!?!?
1080P is a quality you'll only get with a blue ray quality video. Therefore, you won't get 1080P on cable tv. If your cable provider has HD channels available, you'll be able to get 720 or 1080i quality video (on those channels only). For the best quality, make sure you are using an HDMI cable. Just be sure your cable box supports an HDMI output. Your Vizio definately supports that type of input. If you have a PS3 or alternative blue ray player, you'll be able to watch 1080P.
The audio or sound IC (integrated Circuit) on the TV panel maybe bad and need to be replaced. Also, the speakers of the TV may have a weak connection from inside the panel. But my best bet is the first solution i gave. If u are not a qualified electronics technician then take it to a service centre. Joseph Asoh, Abuja, Nigeria
This is a result of poor conversion of a SD signal on a HD channel. Go into your settings and adjust the h/v settings to move the line off the screen. You can do this with a combination of v-position or vsize.
Wow. This is more comon than I thought. My 50" Vizio plasma just went out as will after a loud pop noise. Power button is still lit. Sound continue to come through but no picture. I will dig into it and see if I can find a appropriate solution.
