Kyocera FS-4000DN Laser Printer Logo
Posted on Feb 04, 2009
Does not respond when keys are pressed
Network printer is showing offline and we can't get it back online
  • Anonymous May 11, 2010
    Is the green light on at the nework connector?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 27, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
600
Points
Had the same problem, but printer on server showed on line.
Simple solution for us was to delete the printer on the workstation and add it again. After this, printer showed online again on our workstations.
2answers
I could print before but now it says printer is offline and I do not know how to get it back online
There's a button on your printer that says on-line. Press it.
What is the make and model of your printer. Are you directly connected to the printer or is this through a network?
11helpful
6answers
Epson printer offline
In this section, we provide some practical ways to resolve the Epson Printer Offline Issue. Simply follow the mentioned teachings carefully and fix this error on your own.
If your Epson printer is displaying an offline message, it means that there is some connectivity problem between the Epson printer and PC. ... Incorrect printer settings where your printer is not set as "Default Printer" may make your printer go offline. An outdated printer driver may stop your printer from functioning.
In the same way, How do I put my Epson printer back online?
Verify The Printer Connection
Update Epson Printer Driver
Check Printing Status
Restart The Print Spooler Service
Add A Second Printer
Hopefully, now you can surely Resolve this issue. I Hope, this content is valuable for you to solve the Epson printer says offline windows 10.
Epson Printer Not Connecting to WiFi
Epson Printer is Not Responding
Key disabled message
The Down Arrow and the View buttons are disabled on the T6050 as default because reverse paper feeding is not recommended on the T6050 printer because they only have one pair of tractors which are mounted above the platen. If the printer tries to reverse feed paper, it could cause a paper jam unless the platen gap is open sufficiently to allow the paper to feed down through the gap unhindered.
You can enable reverse paper feeding if you are sure that a paper jam will not occur. This is done as follows. Set the printer to Offline. Press the Mode key: display will show Offline Normal. Press any Arrow key until display shows Offline Oper. Press the Forms/1 key. Press any Arrow key until display shows Oper Forms. Press the CPI/2 key. Press any Arrow key until display shows Forms RevPap. Press the LPI/3 key. Press any Arrow key until display shows RevPap Enabled. Press the Enter key and reverse feeding will be set. Set the printer to Online. Once the reverse paper function has been enabled this option will need to be saved to prevent the setting being lost when the printer is powered off. To save the Menu Configuration; Put the printer OFFLINE Press the MODE button, then press the DOWN ARROW until CONFIG is displayed Press FORMS/1, then press the DOWN ARROW until PRINTER is displayed Press CPI/2, then press the DOWN ARROW until SAVE is displayed Press LPI/3, and with POWERUP shown in the display, press ENTER.
6helpful
My c309 printer and fax photosmart premium is always offline and i cant print anything. how do i change it to online. I run win 7
If I am correct you are using it on wireless/network. If yes, you can try following steps.
On printer press Setup(wrench) button >>>> select Network >>>> select Wireless Setup Wizard >>>> This should show your network on printer >>>> Select your network and enter network password or wep key >>>> Printer should say "connected to network"
It will automatically go to online on computer now.
3helpful
2answers
Printer offline on wireless home network
first make sure the wirelss is enable and you are able to ping the print server .Go to printer and faxes option and choose the printer model which you installed just right click on it you will see the option of use printer online.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
2answers
Printer displaying paper out on on control panel
You may be able to calibrate the paper out sensor to fix the problem.
Press the Enter and Line Feed keys together and hold pressed until the alarm sounds (typically 3 or 4 seconds).
You should have seen briefly displayed, Tech Access On
The display will again say Offline.
Press the Mode Key, display will show Offline Normal.
Press either Arrow key until display shows Offline Test.
Press either Arrow key until display shows Test Diag.
Press either Arrow key until display shows Diag Prnt Cal.
Press either Arrow key until display shows Pap Out.
Press Enter
Follow the instructions on the LCD display, which will advise on removing and reinserting the paper.
After you have compleated the calibration place the pritner ONLINE to exit the menu.
And finally turn the printer power off, wait ten seconds and turn the printer power on again.
If the problem still exits you may need to repalce the lower tractors or the main logic board.
Printer not receiving jobs from computers in office..HELP!
what type of connector do you use? if its network printing then check ip address, cable, and the network card of the machine if it shows light, if its usb cable check the driver or cable.
note: make sure when you press the print buttom on the machine it doesnot show offline! if it shows offline you cannot print hit go or start to make it online.
if none of this work, reset the machine by hitting 1087 twice this will take you to maintenance mode then hit 906 then start, highlight the words that come on screen by your finger then hit start, the machine will ask you to put the main power on and off, do that and you will be fine.
Best Regards
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Top Kyocera Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
