Question about Hitachi H65XXX 1 - 1/8 " Hex Shank Demolition Hammer
Chisel is stuck wont come out - Hitachi H65XXX 1 - 1/8 " Hex Shank Demolition Hammer
    Champion:
  • 304 Answers
Remove chuck assy and see if it will release, it might need a bit of help with a vice. If not then it will have to be taken apart and pressed out.
Posted on Feb 10, 2013
Anonymous
SOURCE:
How do you remove a stuck bit in the chuck of a TE 17 Hilti hammer drill?
Hilti TE56 SDS max stuck chisel remove - YouTube
? 7:10
https://www.youtube.com/watch?v=rmpvYuEvbIk
Jun 22, 2017 - Uploaded by Power tools fix
Hello, In this video you will see how to remove stuck chisel in Hilti demolition hammer. Same can be made for ...
Hilti SFC 22 A chuck removal and Makita chuck replacement - YouTube
? 7:12
https://www.youtube.com/watch?v=gkjBs0f0upg
Sep 15, 2017 - Uploaded by Power tools fix
Hello, In this video you will see how I removed Hilti SFC 22 A cordlessdrill chuck. I replaced genuine Hilti ...
Hilti TE76 stuck chisel remove and repair - YouTube
? 12:53
https://www.youtube.com/watch?v=v3ckL1lQ-2E&vl=cs
Nov 26, 2017 - Uploaded by Power tools fix
Hello, In this video you will see how to remove stuck chisel for Hilti Te76 demolition hammer. Same can be ...
How to disassemble and find problem in for Hilti TE 7 C rotary hammer ...
? 17:45
https://www.youtube.com/watch?v=4yY97AAHPO4 Feb 7, 2017 - Uploaded by Power tools fix
In this video you will see how to find problem in Hilti rotary hammer drill TE 7 C -~-~~-~~~-~~-~- Please ...
remove stuck bit in the chuck of TE 17 Hilti Google Search
Jun 12, 2018 | Hilti Drills
Hitachi H65sb electric demolition hammer. Motor works OK but will only sometimes break concrete. The machine wil vibrate in your hand and appears that this energy is not transferring to the chisel point....
Could be a stuck impact bolt, try banging the chisel hard against the concrete and see if it makes a difference. If not it is probably an internal piston/cylinder fault. Take it to a repair centre. You can get a drawing from Hitachi's web site if you wish to do it yourself.
Feb 08, 2013 | Hammering
Hilti te 56 combi hammer not working
The gears inside that engage the chisel points to move back and forth are either not alligned properly or are stripped. You'll have to open up the hammer to see what, exactly, is the problem.
Sep 20, 2012 | Dewalt D25330K 2KG Sds Plus Demolition...
Trying to remove transmission, does not want to disengage from engine
Several things cause that to happen.
1, The clutch spigot shaft might be stuck in the clutck plate or some dowels between motor and trans could be tight.
In that case you need to sharp wedges on 2 opposing sides of the transmission and wedge the gap wider with a little force and the things will come apart.
2. The damage to the clutching system might have been so bad it heated the parts and fused some of them.
Remove the clutch fork and use the hole to inspect the system. If the release bearing is stuck to pressure plate you should be able to separate box and motor now leaving bearing on pressure plate.
If the bearing is stuck to the plate and shaft try to separate them by inserting a long chisel in thr fork hole and try to separate the parts by chiseling with light taps and rotating the motor in the process.
If that fails then brute force is the answer. Hammer the chisel real hard. You are likely to damage some items though, but that will bw the way out.
Oct 18, 2011 | 1991 Isuzu Pickup
Having trouble removing right front wheel bearing on my 04 vue i tried tapping, chisels, air chisel, penetrating oil nothing seems to work.
The Saturn Vue should have a bolt-on bearing with integrated wheel hub and ABS. It is held on with 3 bolts.
I assume that you got the wheel, rotor, and brake caliper off. You've removed the 3 bolts thru the knuckle to the bearing. And you have the axle nut off and the axle pushed out or at least lose from the bearing spline.
The bearing can get stuck in the aluminum knuckle pilot diameter. The galvanic corrosion between the bearing and knuckle can lock the bearing into the knuckle pretty tightly. It is not a press fit, it's just stuck. I had one GM bearing that had to be pushed out with a hydraulic press.
Keep soaking with penetrating oil and keep hitting it. Otherwise you'll need to remove the knuckle/bearing from the car and find a press.
Feb 27, 2011 | 2004 Saturn VUE
Stuck chisel
if you have access to a vise I would lock the chisel in it and pull on the release collar and then take a dead blow hammer and "tap" on the drill to try and pull it away from the chisel.
Jun 28, 2010 | Bosch 11265EVS 158 Spline Combination...
2007 3500 4x4 trying to replace front dr. sd. u joint without killing sealed bearing with chisel or gear puller bearing wont move! torches?
No good way to go about it. If you have an air hammer, see your local tool guy. They make a bit that hits off the hub bearing bolts to work it out. It works fairly well, but if theyre really stuck, get yourself a big hammer and start swinging.
May 06, 2010 | 2007 Dodge Ram Truck
1999 grand marquis oil filter stuck. Couldn't get it out. All its frame collapse. Decided to destroy it (open it up with jigsaw) and attempted to get to the screw part. I see the screw part but I can't...
I had a similar problem with an Ecort GT years ago. My filter was stuck so I drove a screw driver through it and all that did was twisted off the can. If you can get a chisel in there you can use it and a hammer on the outside base of the filter and chisel a notch into the base and use the chisel in this notch and hit it so it makes the filter base turn counterclock wise and spin it off. It will take so time to do this. Onch you get it loose it will spin right off. Be careful and only chisel on the base of the filter and not the engine. Also if you have room you might be able to use a large pair of spli joint pliers, but I doubt that you have the room. Once the filter comes off make sure that the filter gasket comes off with it.
Oct 25, 2009 | 1999 Mercury Grand Marquis
Problems removing rear right rear wheel hub/spindle
Yes....it's called rust and corrosion. You'll need to obtain a nice, large, sharp chisel and nice hammer and chisel away and the point where the hub and axle flange meet. Be careful not to chisel the axle flange. The hub/bearing are not pressed in, just difficult to remove. If you have ABS, make sure you don't damage the wire from the hub. Disconnect it from the bearing assembly by pushing down on the top of the spring clip and pulling it out, carefully. The connector will come out of the hub with gentle pulling. You will need alot of patience too when chiseling the bearing out. Use lots of "PB Blaster" penetrating oil as well (available at any auto parts store). Do NOT use WD-40, it sucks and is mostly water. PB Blaster comes in a white spray can with a yellow top. Ask for it by name. Good luck to u.
Chris
Aug 02, 2008 | 2003 Dodge Caravan
Hitachi H65XXX 1 - 1/8 " Hex Shank Demolition Hammer Logo
202 people viewed this question
Top Hitachi Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
ray gallant
Are you a Hitachi Hammering Expert? Answer questions, earn points and help others
