My Dell XPS M1210 (Windows Xp) Wont boot up its stuck at a blue screen it says check for viruses on my computer but I cant boot it up..Just goes back to the blue screen./ Run CHKDSK /F to check for hard drive corruption.. I cant boot it up I think I need a new hard drive..Is there ANY Possible way I can fix this for cheap or for free
SOURCE: dell l400 problem
1.If you purchase an external USB CD drive you will not need to use your floppy discs for booting. 2. You can connect a USB CD drive to your system. 3. Your system will recognize any device plugged into your USB drive. 4. There is no CD drive available for internal installation in your computer. 5. With the USB CD drive plugged in and the windows installation disc inserted, your computer should take you through the setup program automatically.
SOURCE: Dell 1501 Inspiron w/Vista won't boot up -- virus?
Hi Erika,
have you tried pressing F8 when it starts booting (keep pressing it before dell bios screen fully loads)
you should get a black screen with options,
scroll up to with arrow keys>> "last known good configeration"
let me know if that works?
also have you installed any programs or hardware befor this happened?
SOURCE: Blue screen on start-up saying 'stop: c000007b bad image' etc
Errr...sounds like fun.
OK well I would stop trying to get Windows back in working condition until after you backup your files.
The easiest way is to remove the hard drive from the system and place it into a usb enclosure.
Backup the files and then reinstall windows.
If you try the band-aid method you'll just end up wasting your time.
Hope this helps.
SOURCE: Error code 2000-0146 in device Hard Drive 1
I just had this same problem a few weeks ago. This error code means you have a bad sector in your hard drive which is cheap and easy to fix. You just need to unscrew the bottom screws holding your hard drive in and place the old cover on the new hard drive you buy. Screw that new one in and reload your programs. Your computer will be as good as knew after that. Look on your invoice to get the hard drive specs so you can buy a new one or just enter your service tag on the dell site and check out the specs of the ones they offer for upgrade.
SOURCE: my dell xps m1330 will not boot up.it comes up on
my dell m1330, don`t boot up black screen thats all :(
[email protected]
Also will a external hard drive with Linux on there solve anything (I feel like I don't know what I'm talking about)
