The camera has been out of use for some time. When used recently a condensation icon appeared but no now. I just won't playback pictures or sound.
SOURCE: Video playback is distorted and has no sound
Usually head cleaner tapes do not do much more than wear the heads out and move the dirt around or in some cases if it is an old tape it may add dirt to the system!!! Someone needs to remove the cassette cover and clean the video drum, tape path, pinch roller and capstan with denatured alcohol. Do not use anything but 100% alcohol as anything else will have contaminates in it. The video head pole pieces are extremely small (we're talking microns) and can be plugged easily. Cleaning the tape guides, audio heads, erase head, capstan and pinch roller is pretty straight forward and the same as any audio deck. Using a lint free Q-tip (or special head cleaning sticks from electronic stores) dip in alcohol and remove any dirt etc from the pieces. Cleaning the video drum is a little trickier. Using the same kind of cleaning stick dipped in alcohol, gently wipe around the video drum assembly. Never, ever go up and down across the face of the head or you could break the video heads!! If you do not know the proper way to do this you should take it to a qualified tech or you could do more damage than good. If you clean your unit the way that I described it should be fine. On occasion I have had a unit with a clogged head that requires a different technique to clean but you would not be able to do this. If cleaning does not work you will need to take it to a repair shop for service. Good luck.
SOURCE: Fault indication
I had this problem before.. It is the carrieage that is out of alignment... It cost me £225 approx to send it back and have it re-adjusted... Hope this helps
SOURCE: Panasonic NV-GS50 black screen
hi also the same problem is there any way to solve the problem,please help me,
SOURCE: F01 error on playback or recording - Panasonic NV-DX100
Panasonic JVC Description
F01 No Take-up reel rotation
F02 E03 No Supply reel rotation
F03 E02 Mechanism has not unloaded to the eject position
F04 E01 Mechanism has not fully loaded to the stop position
F05 E04 Rotation of video head has stalled or to fast
E06 Tape drive motor is not rotating or stalled
F31 Data transmission error
F51 Focus motor is not functioning, No focus
F52 Zoom motor is not functioning, No Zoom
U10 Dew sensor has detected condensation or failed
U11 Video heads have been detected as dirty or failed
Matti Knuutila
[email protected]
