ASUS P5GZ-MX Motherboard Logo
Posted on Feb 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mita Kyocera KM1535 with an error code. C710
I have a Mita Kyocera KM1530 with an error code. C710 can someone help with what the error code is.
Anonymous
Level 3:
Master:
  • Master 848 Answers
  • Posted on Feb 05, 2009
Anonymous
Master
Level 3:
Master:
Answers
848
Questions
0
Helped
361642
Points
2250
C170-Toner sensor/Developer Error
check usual suspects Sensor, Wiring, Developer material, connectors.......
How do I fix an error code C610 on my kyocera km1530 copia?
You can disconnect the negative terminal on your battery for 30 seconds that will clear your error codes for you....Good Luck.....
Call for Service ...... C710
Hi there
I have found various documents which may help you with this problem and possible future problems. This page:
Error Codes Kyocera Mita KM1530 Code C710
can find any code connected with Kyocera mita machines by changing the machine and the error code in the appropriate drop down menus. C710 is identified as:
Description Toner sensor problem
• The sensor output voltage is outside the range of 0.5 to 4.5 V during toner control.
• The toner sensor control voltage cannot be set within the setting range when maintenance item U130 is run. Causes Defective toner sensor. Poor contact of the toner sensor connector terminals. Developer problem.
Another page showing error codes and their meanings is here;
Kyocera Mita Error Code Messages
and this confirms the above.
Also the link below takes you to a Kyocera web page where you can download various manuals for this machine (KM-1530). By changing the product in the drop down menu to KN-2030 you can get similar manuals for this machine.
Download Center
In your question you mention "Compatible KP23153 Black Toner Cartridge 106153" and that led me to wonder if the compatible cartridge is the cause of your C710 error since that is toner related.
Might be worth trying an original cartridge to see if the error goes away.
Hope this is helpful, if so would you please register that with Fixya
Cheers
My kyocera mita is showing c710 after swiching on the machine
The toner container could be locked. Remove toner container and shake well. Switch machine off and back on again.
Hope this helps.
2helpful
Km 1530 displaying ap on screen
Please click here to download the technical guide and user manual.
http://www.kyoceramita.eu/index/service/dlc.false.driver.KM1530._.EN.html#
Kyocera Mita Photocopier KM-1530 Error code AP flashes at start up then C710
When AP flashes the toner is being replenished inside the copier. Wait a few minutes. You need to refill the toner.
1helpful
We have a Kyocera Mita KM 1510 and I am getting an error code C710 and the add toner light is on. I put in a new toner cartridge but the error message and the light are still on. Any suggestions?
C 710 is a Toner Sensor Problem
Defective toner sensor - Replace toner sensor
Poor contact of the toner sensor connector terminals - Reinsert the connector. Also check for continuity within the connector cable. If none, repair or replace cable.
Developer problem - Replace developer.
2helpful
Error c710
it means that toner cannot enter the developing section of the copier, all you have to do is remove the developing unit, then pour it with enough toner, the problem will be solve.
2helpful
2answers
Can not clear Error Code AP
You are out of toner...It means ADD POWDER
7helpful
2answers
Error c710
Your problem could be one of several things:
1) The Carrier (iron filings) inside the imaging unit is deteriorated and needs to be replaced.
2) The Toner sensor inside the imaging unit may be giving an incoorect reading, due to be faulty or because of old toner/carrier mix blockage close to sensor. Give the imaging unit a good service and replace the carrier.
3) The wires behind the black cover of the imaging unit have been picnhed and is shorting on the metal plate
4) The main PCB of the machine could be faulty
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
