Recently the built-in freeview in my tv appears not to be working, I do not recieve digital channels anymore! However when connecting the tv via a freeview box I do recieve the digital channels! I was told this a common problem with toshiba TVs and by upgrading the system via software should resolve the problem. Is this something I can do myself?
Hi there alot of the updates for the system should automaticly download via ariel to the tv to keep you up to date some times if the strenght of the signal isnt srong enough then you might not get the update they send out , one thing i have found is that if you use an ariel booster then this makes the signal stronger this helps particularly if you have more than one tv set up with the same ariel, you could try unpluging all ariels to other tvs making sure the ariel lead you are using has no conections in it as this also gives you loss of signal if there are multiple conections in the lead runing from the ariel to your tv set hope this helps some
Cheers ;)
Analogue signal OK. No Digital. Cannot access setup menu, it flashes on the screen momentarily then disappears.
