DELL GX270 IS NOT SHOWING THE IDE DRIVE IN THE BIOS. WHAT CAN I DO FOR IT.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules
Test all power and data leads that attach to your hard drive IDE
The leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have secure dust free connections and are not faulty. Any bad or faulty power or data lead or connection can cause a computer not boot up.
Motherboard and a Hard Drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail.
SOURCE: vga driver for dell optiplex gx270
If that machine has Internet access, try using Windows Update. You could also try Dell's site.
Geno
SOURCE: BIOS failure ??? DEll Systems OptiPlex GX270 Series
this may or may not help, try taking out the cmos battery out (looks like a watch battery) and leave for a few minutes then replace, this will reset the bios.
SOURCE: FATAL ERROR MESSAGE/DELL OPTIPLEX GX150 DESKTOP/WINDOWS XP PRO
Optiplex 150 I get a message error loading operating system
can somebody help out there?
SOURCE: selected boot device is not available
I had the same issue with my dell dimension 2400. The issue I was having resulted in the connection to the drive was loose. Try taking off the side of the case, find the drives in question and reseating the plugins. My pc was quite a bit older though and i don't know if this will be your solution, but its worth a shot. You can even try installing a different cable and swapping to another power supply plug.
SOURCE: Dell Optiplex GX270 will not boot from disk
The reason why Windows install/setup is not continuing is it is trying to detect the hard drive.
You might have a faulty disk or the MBR (Master Boor Record) on the hard disk is corrupted or virus infected.
When you go into the BIOS configuration, does the BIOS detect the hard drive? If so this is a good sign. If not the hard disk is probably faulty and needs to be replaced.
Next boot up with a DOS floppy boot disk and the run fdisk /mbr
This will fix the MBR.
Next run fdisk again and delete all the partitions on the hard drive.
You do not need to create a new partition with this DOS disk, this will be done with the Windows XP install.
Reboot the computer and now install Windows XP. create a new partition and format it in NTFS (do not do a quick format).
