Hotpoint WMA74 Front Load Washer Logo
Anonymous Posted on Feb 08, 2013
Flashing key symbol
Flashing key lock symbol fom start, even though door securely closed
Anonymous
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 24 Answers
  • Posted on Feb 08, 2013
Anonymous
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
24
Questions
0
Helped
5259
Points
67
Wire may have fallen off switch, or shorted
4 Related Answers
Anonymous
  • 139 Answers
  • Posted on Dec 09, 2007
SOURCE: hotpoint wmm39a
IF you machine is a wma39 not a wmm39a then what has happed is that you control board is blown basically.
TO check this remove the soap draw and you will c three screws remove them... TO make removing the panel easier i would suggest removing the top as well as the front panel is wedged into it.. Then unclip the board from the panel and you will c where the big wiring plug is attached that the tracks on the board are blown.. There is no point replacing the board untill you can work out what has caused it to blow because it will blow again.. Its usually the motor or the doorlock which blows the board.. Trust me i been dealing with this type of machine for years...
Anonymous
  • Posted on Feb 24, 2009
SOURCE: door locked light flashing when door is closed
push on the door where the lock is... it may not be fully locked.
Anonymous
  • Posted on Apr 25, 2011
SOURCE: i have a hotpoint wml 540 p/g/a/k and the cycle
I have had this problem with mine. Turn off the machine at the mains (might be awkward if the switch is behind the machine!) wait a couple of mins and then turn back on again. It should now work!
Anonymous
  • 6277 Answers
  • Posted on Aug 18, 2011
SOURCE: door lock light will not
There is likely to be a problem with either the lid/door solenoid/lock or the 'lid/door closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Bosch Serie 6 Exclusiv won't start washing, door light flashing even after door lock replacement.
please verify with the product documentation that the flashing-door symbol indicates what you've initially mentioned. Apart from that, you might look for the sensor and hold it in to temporarily overcome the issue. If the door being shut is the issue, pressing in the sensor should fix the issue for you temporarily. If not, then you can work with Bosch or Home Deport to moving forward.
Prior to their arrival, you can power cycle your machine 1 or 2 times and check for the door symbol once more. It could be that they sensor has gone bad for some reason.
Thank you
Avital 3100 keyless entry remote sets off alarm when trying to unlock or lock doors with remote. Doors stay unlocked but alarm keeps sounding off and car wont start.
hi'
i think the wire that connects to the door trigger for the interior light
a negative or a positive one has been mixed up
if its neg change it to the positive one
if its positive change it for the negative one
25666027-extj4arg1t42xbh3l3byl5v2-3-0.jpg the purple or green wire
cheers
Siemens washer dryer 1060
its either parental lock or
the door closed detect has failed
so many fail
today ive answered the same thing more than 10 times
you need to check out your home insurance and warranty etc
try get the repair free
if this fails just look for the door lock switch for it
and DIY
2002 l2 saturn security light flashing
Open your car with the key on the passenger side then close the door and go around to the drivers side and lock the doors manually and close the doors while standing out side of the car.
Then use your remote to open the driver side door and start your car.
Display shows flashing 'door' warning,even though door is closed.....then when door is opened/closed a couple of times display will dissapear and re-appear every 3 seconds or so. Help!
The symbol indicates there is a problem with the door lock. Either the locking solenoid or the door lock sensor is malfunctioning and requires attention. Sorry- Service call!
John C
2helpful
There is a light flashing with a a key symbol in it. when i put key in ignition it goes off
It's the security system. That is a symbol for the security system of the car, you can deactivate it by placing the key in the key slot.
You should get that symbol anytime the key is away and the doors are closed. It's normal.
Hope helps (remember rated this answer).
1helpful
I bought a new Keyless remote for a 2007 Forester from a Subaru Dealer to replace an original one that went bad after 2 years. I have followed the directions in the owner's manual to program it, but can't...
IMPREZA: 2005, 2006, 2007 and
FORESTER: 2005, 2006, 2007, 2008
Check for Immobilizer key on Forester XT models only.
information is always subject to change and correction imp05keylessremote1.jpg
new remote for 2005 Imprezas.
This is not the same remote as the 05 Legacy/Outback remote which also has truck/gate release on the front and a red panic button on the back.
Lock: press Lock button for 2 seconds or so to lock car, and arm optional security system. The car with chirp once and turn signals flash for locked, 5 short chirps and signal flashes if any door is not fully closed. The dome light goes on for 15 seconds and ignition key ring (if present) will light for 30 seconds when unlocked.
Unlock: press unlock one time for driver's door, press again within 5 seconds to unlock all doors inkling rear gate (wagon). The system does not open the trunk.
Panic mode: press and hold lock button for approx. 3-4 seconds to activate Panic mode. I panic model the horn honks and turn signals flash until either the lock or unlock button is pushed again.
Finder mode: Press lock button 3 times within 5 seconds to activate Vehicle Finder mode. The horn will honk once and the turn signals will flash 3 times
Distance: works within approx. 30 feet depending on battery strength, nearby concrete walls and etc.
Audible Chirp On-Off: the system will chirp when locked or unlocked. To turn OFF the chirps, unlock the door and then push both lock and unlock buttons at the exact same time for 2+ seconds. There will be 2 chirps indicating the the audible is off. To turn the chirp back on, repeat the process and the system will chirp one time when it is back on.
Battery: as the battery ages it will only work as you get closer to the car. When a battery is replaced, the transmitter must be re-synchronized with the Keyless control unit. To synchronize, press the lock or unlock button 6 times.
Programming: 4 codes may be programmed.
Sit in driver's seat and unlock all doors. Open and close the driver's door
Turn the ignition key from LOCK to ON position 10 times within 15 seconds. Be sure to stop at both lock and on. The horn will HONK once to indicate transmitter programming mode is activated. Leave key in LOCK position and don't remove it from ignition.
You now have 45 seconds to complete the programming as below.
Open and close driver's door again.
Push either lock or unlock button on the remote you want to program. The horn will honk 2 times when successful.
To continue and program other remotes at the same time: open and close the driver's door and push lock or unlock on the remote. The driver's door must be opened and closed between each remote you want to program.
Done programming? remove the key from the ignition and the horn will honk 3 times.
DELETE old codes? Reprogram 4 times, it will overwrite old codes.
Alarm Security System: optional on all models. When locked there is one chirp (can be turned off, see above), the turn signals will flash and the red 'security' light will start to flash once every 2 seconds except for STi which flashes twice every 2 seconds.
There will be 5 chirps if a door, hood, and trunk or gate is not fully closed
You can also arm the system by using the power lock button on the driver or passenger door as you get out of the car and then closing the door behind you.
Disarm the system: push unlock for 2 seconds
Lost remote, alarm activated? When you can't use a remote to turn off the system: open the door with a key or try to start the car and the horn will start to honk. Turn the key on-off 3 times within 5 seconds and the alarm will go off and you can start the car. It's simple!
VALET mode: To set valet mode or just to disable the security alarm system: 1. unlock all doors 2. physically open the driver's door 3. hold the UNLOCK button on remote for 2+ seconds. The red 'security' light will then flash 2 times a second until the car is turned on.
System has been Tripped (except for STi): if you unlock the door with the remote and it chirps the signal light flash 4 times, the system has been triggered;
Identification mode: To find out what happened and why the system was triggered:
Open and drivers door, leave it open. Turn ignition key from LOCK to ON 2 times and then leave in LOCK position.
Tripped code: 1 security light flash: a door has been opened, 3 flashes when the impact sensor was triggered, 4 flashes when the ignition was messed with or battery disconnected
1helpful
94 Chevy Camaro-won't start
I would say you would have to take off the inside door panel and remove the mechanism and security switch to see why it is jammed in a locked position, even though you have unlocked the door the electric switch {maybe rusted} is still signalling a lock position, the switch may be located on the actual key barrel, but same check to see why its not moving into an unlock position.
hope this helps.
2answers
F dL symbol on Whirlpool duet HT
It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
1helpful
Security lights flashing after battery cable removal-no start
Anytime you disconnect and reconnect your battery, the factory alarm will arm upon reconnection and the truck will not start. You have to close your doors, then manually lock and unlock the door with your key. This should turn off the security system and you should be able to start the truck.
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
