SOURCE: toshiba regza
the best thig and easiest way would be to reset everything and start overthose things have so many differnt settings but to start turn it off then on the right side it has a power button, hold that power button down for 5 seconds and its reset.
SOURCE: I have a 2 year old Toshiba 32
Your panel is defective.Not worth repair.Try calling Toshiba customer support and see if they will help you.
SOURCE: How do I retune a Toshiba Regza 32AV615DB 32-inch
what are you trying to do ?
if your trying to re scan your channels then go into youe setuo menu and rescan channels in cable mode if your on cable or antenna select air
SOURCE: toshiba regza 37" reset defaults
Unplug the TV for some time (usually 1hr is plenty) and it should reset to factory settings.
