My monitor is just tuning itself off every 5 seconds, like literall, im really getting sick of it, i dont have a spare monitor to test the wires, and when it turns off, straight away the blue power light on the monitor goes off,then quickly back on with the rest of the screen,coming after it, this is wt its like, d.i.y click the power button on ur monitor,then quickly press it back on, do this after 5 seconds each time,now imagine that every 5 seconds without actually touching the button,im not pressing anything when this happens,but even when i press a button it goes off, regardless of wt im doing, plz help me
SOURCE: lg flatron w2234s monitor is flashing ??
The problem is the VGA part of the moniter is playing up. Two areas, one the MCU on the vga card, the other is a faulty transistor on the vga card. Repairs on a PCB VGA circuit are impossible with out the right tools.
The part number you require are Manufacturer Part Number EBU59489401
Board Numbers 791501300700R
For a replacement card
if no warrenty
Some thimes the 5 sec can be 20 to 30mins.
i have same problem in works exactly 5min and the it turns off for 30-35 sec and turns on.also tried another power cable and same problem.
my monitor started doing the same thing today ... after 3 months of use.
just turns off/on every 5 seconds
I have problem with same monitor .. when i turn on monitor , a little bit lighter than black screen was and then black screen but still blue light on downright
Same problem here on the same monitor. Only stays on for about 5secs.
Sounds like the monitor is bad. Does it also do this when you first turn on the computer and its booting up?
