Question about Frigidaire GLTF1670A Front Load Washer
Front loader GLTF2940ESO frigidaire washer
The fabric softner and bleach are no longer being siphoned out into washer, the tray is spotless and no visible build up any where in side the tray or in the washer under the tray, can some one help me please.
Thanks Susan
  • lalucabu3 Feb 08, 2009
    Hello Joyce,
    Soap is on left side, goes into washer when being poured in, fabric softner and bleach on right side of the tray and should be dispensed at the proper time but no longer working, machine is 31/2 yrs old, not one tec will tell me a thing over the phone and sometimes its not worth fixing. Have a good day.
  • Anonymous Feb 12, 2009
    I have the same problem with my fabric softener dispenser. I even took the insert out, and cleaned the whole thing out with paper towels, but the reservoir does not empty during the wash cycle.
    -Ellie
    Scholar:
  • 99 Answers
This is joyce
can you exsplain what is going on with your washer?
Posted on Feb 07, 2009
  • Anonymous Feb 07, 2009
    this is joyce
    My front loader sprays water into trays and the detergent runs out, how does yours work?
    joyce
6ya staff
SOURCE:
Soap, bleach, softner dispenser not working
Here is a tip that I wrote about what I found out about the fabric softener not dispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going into washer
heatman101
Dec 28, 2010 | Frigidaire ATF6000ES Front Load Washer
Water fills up in the bleach and softner side of the drawer
Here is a tip that I wrote about what I found out about the fabric softener notdispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going intowasher
heatman101
Oct 25, 2010 | Frigidaire ATF6000ES Front Load Washer
Bleach & Fabric softner tray not working.
Remove the drawer by pushing the tab at the top of the drawer and pull it out and check for an obstruction. They regualarly plug up with gummy fabric softenener. Try washing out with hot water and reinstall
Apr 04, 2010 | Frigidaire GLTF1670A Front Load Washer
Frigidaire Washer (CRTR9300AS0) the liquid bleach fabric softner containers are filled with water after each use. Now it appears that water is leaking from the bottom. Any idea what this could be
This could be a very simple fix, if it is indeed coming from the fabric softener area. It could be that there is simply a clamp that has come off the connection, and the supply line has came off as well, or has broken. There about 4 lines in the fabric dispenser area and if one has come off it will certainly leak. Also there is a hard plastic siphon that may have a pin hole in it. however this is unlikely. hope this helps.
Thanks
Oct 14, 2009 | Frigidaire ATF6000ES Front Load Washer
My HE washer doesn't dispense the fabric softner
Try removing the dispenser cup - and washing the inner cup thoroughly- run a sanitary cycle with whites and chlorine bleach mold and mildew likes to haunt these front loaders - be sure to run a bleach hot water cycle once weekly
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
FABRIC SOFTNER DOES NOT DISPENCE
Check to make sure the litle cups are set in place correctly and also make sure they are not blocked with hard fabric softner. A quick test: pour water directly into the fabric sofnter cup and fill it up,IF it siphons out, you will need a new inlet valve for that unit. The inlet valve has soliniods on it for the bleach & fabric softner.
Good Luck!
Feb 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Fabric softner does not empty
I had a similar problem and removed the complete dispenser drawer and washed it in with hot water. The small inner cups for the fabric softener and bleach should be removed and the hot water directed into the small "stand pipes" on the back side of the covers. It appears the fluids in the cups are siphoned out and if the pipes are clogged at the bottom there will be no flow. Also is the plate is not fully seated, the siphon effect is will not work.
Also, my wife said she does not use the cheaper brands of fabric softener anymore because we think that might have caused some of the clogging.
As a side note, if you remove the top of the washer, there is an adjustable dial where you can fine tune the amount of liquid dispenced. You can try adjusting that too. I think my final fix was to clean the back side of the face plates inside the dispenser and ensure they are fully seated to allow the proper siphon effect.
Jan 15, 2009 | Frigidaire GLTF2940ES Front Load Washer
Front Load Does not dispense fabric softner and bleach
under the bottom panel of the washer on the left hand side is a tech sheet that will tell you how to fix this
Mar 05, 2008 | Frigidaire GLTF2940ES Front Load Washer
Fabric Sofner won't dispense
hi there remove the soap drawer then remove the cover over the softener compartment you will more than likely find a blockage in the cover siphon or the down tube on the drawer
Feb 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire GLTF1670A Front Load Washer Logo
183 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
jimorris77
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
