Motor keeps shutting off by itself. Does anyone know what the problem could be?
My suggestion for this is simply get a new on and off switch to put on it and this should fix the pronblem
Find and clean all filters,if an air compressor is available take it apart what you can and see if you can get to the motor and blow it out and check for restrictions in hoses,motor has overload protection and dirt will make it overheat and shut off when it cools down then it works again and or check electrical cords and sawitches
i have a 6500 epic series cannister vacuum and while i am
vacuuming, it stops and starts, stops and starts. when i take
the power nozzle off the vacuum it works ok. when i put the
power nozzle back on, it stops and starts again. is it the power
nozzle that's the problem.
