Canon Pixma iP2600 Photo InkJet Printer Logo
Posted on Feb 10, 2013
Power button does not light - Canon Pixma iP2600 Photo InkJet Printer
Anonymous
Level 1:
New Friend:
  • Contributor 17 Answers
  • Posted on Feb 10, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
17
Questions
0
Helped
4640
Points
37
Check that the cord is fully depressed into the back of the printer.Is power coming through? will it function, if so then it is the led inside the printer.
1helpful
Hp deskjet 948c. What Do The Button's Do
buttons and lights The HP Deskjet printer buttons let you turn the printer on and off, cancel a print job, or resume printing. The lights give you visual cues about the state of the printer
sayurisan20_33.jpgcancel button
print cartridge status symbol and light **The light above the Print Cartridge Status symbol flashes when a print cartridge is low on ink or incorrectly installed.
sayurisan20_35.jpg resume button and light
**The light above the Resume button flashes when an action is required such as loading paper or clearing a paper jam. When the problem is fixed, press the Resume button to continue printing.
sayurisan20_36.jpg power button and light **
The Power button turns the printer on and off. It takes approximately five seconds for the printer to turn on after you press the Power button. The green light above the Power button flashes when printing is in progress. Caution! Always use the Power button on the front of the printer to turn the printer on and off. Using a power strip, surge protector, or a wallmounted switch to turn the printer on and off may cause premature printer failure
7 beeps with the orange light means?
To fully reset your printer you can try this method. It works for most Canon Printers. It should solve any issues you are having.
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button.
(DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and
Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button the specified number of time(s)according to the function listed in the table below. (Each time the Resume/Cancel button is pressed, the Alarm and
Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
1helpful
Blinking ornge light
reset your printer if you try you can i will give you 6 tips
Here this manual way step by step to resetting waste ink counter on printer canon iP4000.
  1. With the printer plugged in and powered off, press and hold the Resume/Cancel button, then press and hold the Power button. Do not release the buttons. The LED light should be green to indicate that a function is selectable.
  2. While holding the Power button, release the Resume/Cancel button, do not release the Power button
  3. While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.
  4. When the LED light is green, press the Resume/Cancel button 4 times. Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.
  5. Press the Power button. The LED lights in green, and the reset is performed. When the operation completes, the printer returns to the menu selection mode automatically
  6. Press the power button to exit service mode.
see you can where is blinking orange light
2helpful
How can I reset the waste ink counter in the printer Canon Pixma IP4200 ?
you can reset it following this procedure:
  1. With the printer plugged in and powered off, press and hold the Resume/Cancel button, then press and hold POWER button. Do not release the buttons. The LED light should be green to indicate that a function is selectable
Then you should do this http://erkinson.altervista.org/blog/2010/canon-ip4000-disassembling/
4helpful
Alarm lights keep blinking after I changed my printer ink.
E5 means cartridges error - to fix press the "stop\reset" button for 5-7 seconds and then release it.
You can also try this:
1) With the printer power turned off but connected to a power source, while pressing the Resume/Cancel button, press and hold the Power button.
4 times----Green (Power)------Waste ink counter resetting
1helpful
Waste ink tank full, what do I do?
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The LED lights in
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the
Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.)
4) When the LED lights in green, press the Resume/Cancel button 4 times (Each time
the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.)
5) After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes,
the printer returns to the menu selection mode automatically.)
2helpful
Hhp deskjet 5550 - orange and green light keep
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.) 2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.) 3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons. 4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times. Finally press the Power button.
3helpful
Canon ip 4200
4) When the Power LED lights in green, press the Resume/Cancel button 4 times, the green (power) led should be lit to reset ink absorbers.
(Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
5)At the end of the service mode, press the Power button
1helpful
Canon ip4200 waste absorber is full
1helpful
2answers
Error number 1700 canon s9000 printer
knowing printer manufacturers I doubt they even have a sensor to detect that its full at all, they probably based on something crumby like print count. here are some instructions to reset the waste ink tank, the instructions vary so try them until one does the job :
Waste Ink Tank Reset
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice, then release all buttons
5: When the indicator lights steady, press RESUME three or four times. The indicator should be orange.
6: Press Power to set data
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
1. power off Printer
2. Push and hold resume button and push power button
3. Hold Power button and release Resume button
4. Push Resume button twice ( 2x ), and now release resume button and power button
5. Green light will blinking and stop.
6. When green light on, push resume button 4 x
7. Push Power button and printer will off, if that isn't off, push power butto again until print off position.
old marine
old marine
ZJ Limited
ZJ Limited
