I have my photos on my imac in nikon view nx2.How do i transfer these photos from view nx2 to my iphone 5
You can export photos on view nx2 to computer first. And then transfer photos from computer to iPhone with iTunes/iCloud or other tools. As for transferring photos from computer to iPhone, you can follow the below steps.
Using iTunes to sync photos with iPhone is also easy. As a media management center, iTunes helps you easily manage data and files (purchased and non-purchased) on your iOS devices (iPhone, iPad and iPod). You could easily sync data and files to iPhone with iTunes. But you should be very careful of the syncing function of iTunes because it is a double-edge sword. Once wrong click, you may lose data in your iPhone. You'd better back up your iPhone to iTunes before you try to sync photos to iPhone with iTunes. The following steps are going to show you how to transfer photos from PC to iPhone with iTunes:
1. Plug your iPhone into computer via the USB cable. Launch iTunes if it doesn't launch automatically. Make sure that you have the latest version of iTunes.
2. Click on the device icon in iTunes.
3. In the sidebar on the left side of the iTunes window, click Photos tab under your iPhone.
4. Click the box next to "Sync Photos". If instead you see "iCloud Photos is On", all of your photos and videos are already on all of your devices that use iCloud Photos. You don't need to sync them through iTunes.
5. Choose the app or folder that you want to sync from. If you choose to sync a folder with sub-folders, the first level of sub-folders will appear as albums on your device.
6. Choose to sync all photos and albums or selected albums.
7. Select "Include videos" to sync the videos from your app or folder too.
8. At last, click the "Apply" button.
For more methods, check: How to Transfer Photos from PC to iPhone
SOURCE: Can I transfer photos back to the card after editing the images?
Connect the cam to a pc and turn it on. Discard the box that pops up. Open windows explorer. You'll see Removable Disk listed in the folders pane. Drop all image files you want to transfer to a folder named Nikon under the Removable Disk folder. But the files must be named DSCNxxxx for the camera to understand them.
SOURCE: camera not recognised on computer so unable to transfer photos to
Try reloading drivers software that came with the camera.
SOURCE: Nikon d40 will not transfer photos.
I have a card reader on standby for when the cord stops working. So far, I haven't needed it.
SOURCE: When viewing photos some white areas blink black on the lcd.
This is becasue those flashing areas are over exposed highlights. Reduce you exposure compensation a stop to capture those white areas. Increase your shutter speed or use a smaller aperture (f-stop) to let in less light. When you loose highlight detail in a digital image it is hard to reclaim back on a computer program.
SOURCE: Nikon d50 monitor does not work during photo
This is completely normal. The monitor is used for setting menu items, displaying shooting info, and reviewing images. Like SLR have functioned for over fifty years, you take pictures by composing and framing through the viewfinder. Only the most recent dSLRs have the Live View capability which allows you to use the monitor like a point&shoot camera.
Testimonial: "Thank you that is waht I suspected, I just wanted to be sure."
