The washer has either a blocked or faulty pump, or a blocked filter.
Depending on the model number, the filter is either at the front bottom behind a removeable panel, or at the rear of the washer.
If you can't find a filter at the front, then remove lower rear cover of washer, remove the large black hose fastened to the bottom of the tub. Be careful, as there will be water run out.
Remove and clean plastic filter in hose.check pump is not blocked.
Refit filter and hose.
Please rate my fixya solution.
Thankyou.
