SOURCE: Another flood. GE washer
The water sound is normal. There is a solution in the top of inner tub for balance. Is it overflowing...as in not stopping the fill cycle? If so check to make sure small hose is still attached to outer tu at bottom left front. This dome that it connects to can become filled with scum and causes the unit to not know that it's full. This causes flooding. You can try removing hose and cleaning out with thin wire. Sometime only fix is to replace outer tub. Again, this is only if overflowing!!
Another possibility is a bad break allowing outer tub to spin in agitation. This throws water up over sides of tub. Monitor unit when agitating to see if outer tub picks up speed and starts to spin. It is normal for it to index.
SOURCE: bosch frontload washer will not drain
Hello Mamma5, It sounds like the drain pump is either seized or jammed. The drain pump has an anti jam device in it. Since you have figured out how to get into the drain pump, try turning the inpeller in the back. It will be a little hard to turn as the magnets in the motor will fight you on this. Look close in case there is anykind of thread wrapped around the inpeller. If so, then you can free the pump. If you cannot free it to run, advise the repairman what you found so he can bring a drain pump with him.
Hope this helps.
SOURCE: LG WM-2277HB washer does not drain and make rattling noise.
You will need to replace the drain pump motor. The pump impeller has separated from the motor shaft. You can push it back on, but it will just come off again. I have not tried adding adhesive because I didn't want a call back. That may work if you want to try it. To replace pump motor:
Take the rectangular recess out by using a putty knife on the left or right side, Remove phillips screws mounting pump. Pull machine forward about two feet to allow you to tilt the machine back to lean it against the wall. Reach under to access the pump. It is held in place by a plastic tab you can depress to remove, but if you break the tab, don't worry, as the mounting screws will hold your pump in place just fine when reinstalled. Remove pump by disconnecting hoses and electrical plug. Change out pump motor (three phillips head screws)
SOURCE: Drain Pump Filter Leaks on LG TROMM WM2277HW
I had to remove the two little plastic tabs that prevent you from tightening the filter plud too tight. Grind these two tabs off and you will find youare able to tighten the pluf just a bit more and it will no longer leak.
SOURCE: LG WM2010CW filter drain no draining
In all likelihood the rubber drain hose is clogged. I had the same problem with my LG front loader. The hose was clogged with sand and dirt almost the entire length of the hose. The following solution is far simpler than taking the dryer apart to clear the drain hose. Besides I figure this same thing could keep reoccurring with all the sand and dirt we get in our clothes here in East Texas.
I purchased about 4 feet of 3/16 inch OD vinyl tubing and adapted it to fit on the end of a garden hose. The adapter gizmo included a valve so I could control the water flow and not give myself a bath. A picture of the gizmo is included below. Make sure that when you connect the water hose to the faucet that the faucet valve is just slightly opened and that the gizmo valve is closed. Using the gizmo is straight forward. First remove the drain filter and than insert the vinyl tubing in the end of the rubber drain hose and slowly open the valve on the gizmo. Make sure you have a large pan or bucket underneath the drain hose to catch the debris and water. Slowly advance the tubing up inside the hose until it won’t go any further. By this time water will also be running out of the drain filter cavity which will indicate the clog has been removed. Continue back flushing for a few more seconds to assure all the debris has been cleared, than clean up and you’re finished.
