Samsung big screen tv model pcl542r has a green or red tint to picture
My samsung tv has a green or red hue to the picture.the picture is also quite dark,
i have a vizio 50 in tv that has a red tint in picture can someone tell me why
If the component cables are to connect your television and they are not correctly connected, this can cause a greenish colour picture to occur on the screen of the TV . A high colour tint setting will generally create a green image on the TV's screen where as a low tint will create a more red hue then. The buzzing could be coming from the cables not being properly connected to the TV.
If the lines are across the screen there is a good chance there is a power supply/ inverter problem in the TV. If the lines are thin pencil lines up and down there could be a problem in the display panel,
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
the tv had intermittant solder connections already but h\they appeared when the tv was moved to hook up the digi-box. The solution could be as simple as resoldering the power convergence amps.
Here is something that may help from the toshiba.com website under your model number television. Q. Why are people on my screen green? Models: 32HL17, 37HL17, 42HL17, 42HL167, 47HL167, 52HL167, 42HL167, 42LX177, 46LX177, 52LX177, 57LX177 REF:FAQLCD00107 If the problem is not the connections, try adjusting the tint on your television. A high tint setting will usually create a green image on the screen where as a low tint will create a more red hue. In order to access your television's tint: 1. Press the “MENU” button on your remote control and use the LEFT or RIGHT arrow keys and select the VIDEO menu. 2. Then use the UP and DOWN arrow keys to highlight PICTURE SETTINGS and press the "ENTER" button on your remote. 3. Next use the UP and DOWN arrow keys to highlight TINT then use the LEFT or RIGHT arrow keys to adjust the TINT. If the picture is too green the tint will need to be lowered. 4. Once you have adjusted the tint to your liking, use the DOWN arrow key to highlight DONE and press ENTER. The toshiba customer service telephone number is : 1-800-631-3811. I hope this helps you with your problem.
Try resetting the TV by unplugging from wall outlet for 3 to5 minutes then plug back in. If no fixya take front grill off and panel and adjust the screen controls, turn color off adjust for Black & White Picture. Good Luck, big IRISH.
do you have a service manual for this tv because it may be your red drive circuit and you need to trouble shoot it if you don't have a service manual for your tv I will post a link where you can get one plus free online tech support to help you troubleshoot this problem http://servicemanuals.vstore.ca/
is the TV still under warranty. if it is I would call Vizio and request a main board be switch and if it is not under warranty I would call a TV Repair shop and have them put in a Main Board.
i had the same prob on my 28 inch hd sanyo crt , i took it apart and reconnected a few plugs and havent had any trouble yet { be sure to unplug it and b quite careful even then} saved me a couple hundred $ !!!
The picture is red
