Can change channels. Have unplugged the TV, still no picture when plugged back in. Screen still black. Help, please.
SOURCE: We have a Vizio model # GV47LFHDTV10A. When we
For the cheap guy like me who will probably do more harm than good:
Also check for the F3 Fuse on that same main input board. It is located in the upper right corner. Hard wired fuses; very small. You will see F1-F4 (F4 is empty). You can solder a replacement fuse right over it. I would recommend piggybacking the fuse with a fuse you can replace. Will need the holder and a new fuse. 6 bucks.
Doesn't solve problem, but I can go another 2 1/2 years and the wife won't blame me for screwing up the TV in the first place.
SOURCE: The LCD screen is dark with no sound or picture when turned on.
I had the same problem after having a Vizio for 2 and a half years. I
left the room for a minute, i came back and the screen went black.
There was still power to the unit and you could see that the back light
was working, just no picture, no sound, and you couldn't use any of the
buttons. The only way to turn it off was to unplug it. It would then
start up, with the Vizio logo going from orange to white, and then do
the same thing all over, no pic or sound.
HOW I FIXED MINE:Look through the back vents for a white light to make
sure the backlight still works. I ordered a new "main PCB" from
tigerdirectparts.com
(you can also use searspartsdirect.com). This is the circuit board with
all of the inputs on it (hdmi, cable, etc.) I opened it up,
disconnected the old one, put in a new one and now it works fine. I
used
both serial numbers on the board to search for it online. It cost me
$144 to do it, but that's better than $450 for a new TV. My tv is the
vx32l hdtv10a. I hope that helps.
For me the part number was either (depending on the vendor) : 0171 2272
2174 or it was 3632 0212 0150. Check your circuit and see if any of
those numbers match up.
SOURCE: VIZIO TV Black screen. Cannot turn off TV without unplugging.
I had a similar problem after having a Vizio for 2 and a half years. I
left the room for a minute, i came back and the screen went black. I didnt hear an arcing sound though.
the same thing all over, no pic or sound. I would check the ceramic fuse first on the board that gets power from the plug.
HOW I FIXED MINE: I ordered a new "main PCB" from tigerdirectparts.com
disconnected the old one, put in a new one and now it works fine.I used
SOURCE: my vizio vx32L turns on but only a black screen shows up
used
SOURCE: no sound after I change the channel. If I turn the
There is an incompatibility between Fios and Vizio audio. To fix the problem, on the Fios box, press "Power" then "Select" then "Menu", one right after the other. This accesses a secret menu on the Fios box. Using the arrow keys on the front of your Fios box, arrow down to "Additional HDMI Settings" then press the right arrow. Another menu will appear (may take a few seconds). Arrow down to "Audio Out" and press the right arrow to change from "Auto" to "L-PCM". Press the Power button to exit the menu. This should solve your problem. Thanks to Vizio tech support for the answer.
