is the number DLE1101W if it's on off and continues to run everything runs through the computer board so without seeing the dryer in front of me i'd have to say you have a bad board,if it runs like normal,heats up spins the clothes shuts off when you open the door but just isn't stopping when it's on off sounds like the board is bad.part
EBR71725805
Possibly a faulty run capacitor in the control box. This is fairly common to LG. the fan motor and compressor use them to start and run more efficiently and when they fail the fan or compressor either don't start at all or run poorly. You can usually tell if you can hear the compressor 'hum' briefly then stop every 10 - 30 secs. this is the compressor trying to start but unable due to the faulty part. LG often have a dual capacitor (two capacitors in one case) so the fan may stop working also or at least run slower. They are common parts available at most electrical wholesalers although the genuine LG parts are normally dirt cheap. Need a model to check the circuit diagram to be more certain.
? 5:29
https://www.youtube.com/watch?v=b74Mt5sSgRI
Dec 21, 2012 - Uploaded by RepairClinic.com
Dryer Thermal Fuse Replacement - LG Electric Dryer Repair (Part ... The most common reasons for replacing the thermal fuse are when the dryer won't start or ... I have an LG GAS DRYER model # DLGX8001V and it will not ... My front load dryer won'tturn on. .... My LG dryer recently stopped working.Missing: seconds
Apr 1, 2006 - I own an LG Electric Dryer model DLE0332W. ... Serviceman: The part you need is a heat regulator and its going to run you about $20 and the labor ... Look into the hole to the left and you will see the Heater Unit right within reach. .... Came back a second time because it still wouldn't dry my clothes (maybe ..
Should like your unit is working fine unless this is constantly happening. If this is a constant thing then condenser coil if dirty,check thermostat setting
I am not very familiar with this particular model but I would see if it has an economy setting on the controls in which case the fan will run non stop while the unit is turned on. Thank you.
