try closing your app open apps by clicking left hand button then should come up with your apps what you been on at bottom it should say close app it draining your battery if that does not work you may need a new battery
Delete cookies and run a virus scan. There's more but start there. Make sure all your open files are closed. Is your storage almost full? That will slow it down. How many devices are running off your router? Make sure you stay within its capacity. Run a speed check make sure it's the parameters your paying for. Make sure your updates are up to date.
Make sure that you are using the correct charger and if you are, your battery needs to be replaced. Overheating while charging or heavy use is a sign that it is near the end of the useful life.
Well one way through the software.... is to on the desktop right click and go to screen resolution - advanced and set the screen to be off in certain minutes. When you close the nextbook should be off also.
Tablets are designed to not heat up much at all, let alone overheat. If it is overheating, there is a hardware problem that is causing that. If it is still under warranty, get it replaced.
my nextbook 8se is also overheating
